  • Jonas Høiby 30 posts 20 karma points
    Jun 11, 2009 @ 14:05
    Jonas Høiby
    XSLT counter without using position ..
    Any idea on howto do this?
    I want to make a counter that counts 5 newsfeeds from the last 5 created sub-pages to a page ..
    problem is - i cant use position because of the xsl:if that makes sure that unwanted pages doesnt end up in the same feed..
    any help would be appreciated .. :-)
    Jun 11, 2009 @ 14:06
    Jonas Høiby
    [code]
    [/code]
    tried this .. and theres a page created later than the one showing .. so position says 2 instead of 1 .. so .. thats why i wanted to make a counter instead .. :-)
  • Tommy Poulsen 514 posts 708 karma points
    Jun 11, 2009 @ 14:21
    Tommy Poulsen
    Jonas, you can probably get by with position() anyway, but instead of using your if-statement, move the clause to the for-each
    So instead of:
    [code]
    Tommy
    Jun 11, 2009 @ 14:53
    Tommy Poulsen
    ooops, sorry, did not read you code correctly.
    Here is what you could write :
    [code]
    Tommy
    Jun 11, 2009 @ 15:13
    Jonas Høiby
    nice thanks - ill try it .. :)
