  • Anna Gurova 9 posts 29 karma points
    Mar 23, 2011 @ 10:25
    Anna Gurova
    Using asp:AdRotator in XSLT
    I'm trying to add a list of banners to my template.
    For it I created two document types: one for list itself and another for single banner. I added property for advertisement xml file into banner document type. This xml I placed in media.
    In my template I need to get following:
            <table>
                <tr><td> <asp:AdRotator runat="server" Target="_blank" AdvertisementFile="~/media/502/adds.xml"/>
                <tr> <td> <asp:AdRotator runat="server" Target="_self" AdvertisementFile="~/media/502/adds.xml"/>
            </table>
    I try to do the following:
    1. In my template I added
     <umbraco:macro alias="umbBunnersListItems" runat="server"></umbraco:macro>
    2. My macro uses xslt. I tried to write like this
    <!DOCTYPE xsl:stylesheet [
      <!ENTITY nbsp "&#x00A0;">
    <xsl:stylesheet
      version="1.0"
      xmlns:xsl="http://www.w3.org/1999/XSL/Transform
      xmlns:umbraco.library="urn:umbraco.library" xmlns:Exslt.ExsltCommon="urn:Exslt.ExsltCommon" xmlns:Exslt.ExsltDatesAndTimes="urn:Exslt.ExsltDatesAndTimes" xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath" xmlns:Exslt.ExsltRegularExpressions="urn:Exslt.ExsltRegularExpressions" xmlns:Exslt.ExsltStrings="urn:Exslt.ExsltStrings" xmlns:Exslt.ExsltSets="urn:Exslt.ExsltSets" xmlns:tagsLib="urn:tagsLib" xmlns:BlogLibrary="urn:BlogLibrary"
      exclude-result-prefixes="msxml umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings Exslt.ExsltSets tagsLib BlogLibrary "
    <xsl:template match="/">
        <table>
          <xsl:for-each select="umbraco.library:GetXmlNodeById(1164)/Bunner">
            <tr><td>
            <xsl:element name="asp:AdRotator">
                 <xsl:attribute name="runat">server</xsl:attribute>
                 <xsl:attribute name="Target">_blank</xsl:attribute>
                 <xsl:attribute name="AdvertisementFile">
                  <xsl:value-of select="./pathToXml"/>
                 </xsl:attribute>
              </xsl:element>
             </td></tr>
          </xsl:for-each>
        </table>
      </xsl:template>
    </xsl:stylesheet>
    but I get an error:
    System.Xml.Xsl.XslLoadException: "asp" .(Prefix "asp" not found)
      C:\inetpub\wwwroot\energotrade.ru\xslt\634364794739606274_temp.xslt(19,9).
    System.Xml.Xsl.XslCompiledTransform.LoadInternal(Object stylesheet, XsltSettings settings, XmlResolver stylesheetResolver)
    System.Xml.Xsl.XslCompiledTransform.Load(XmlReader stylesheet, XsltSettings settings, XmlResolver stylesheetResolver)
    umbraco.presentation.webservices.codeEditorSave.SaveXslt(String fileName, String oldName, String fileContents, Boolean ignoreDebugging) C:\Users\Administrator\Desktop\\Sources-binaries\Umbraco\umbraco 4.5\umbraco\presentation\umbraco\webservices\codeEditorSave.asmx.cs: 127
    Then I tried to add xmlns:asp="asp" in <xsl:element name="asp:AdRotator">, but this didn't help.
    Is there any way rto solve this problem? Or may be you can advise me another way to add banners dinamically to my template.
  • Richard Soeteman 4054 posts 12927 karma points MVP 2x
    Mar 23, 2011 @ 11:50
    Richard Soeteman
    Hi Anna,
    the asp.net AdRotator is a server control. You can't use these controls in xslt. What you can do is create a usercontrol and use that as the macro. On the usercontrol you can put the AdRotator.And i think (not sure) you can use it in a Razor Macro also.
    Richard
    Mar 23, 2011 @ 16:10
    Anna Gurova
    I created UserControl with AdvertisementFile public property - macro parameter.
    <umbraco:Macro AdvertisementFile="~/media/502/adds.xml" Alias="AddRotatorControl" runat="server"></umbraco:Macro>
    But I need AdvertisementFile to be set to property of object in my Content.
