I am absolutely new to umbraco, so I might be trying to do something silly here. But what I am trying to achieve is write a general macro that will input an img tag with the src attribute set to the appropriate image url. And the image is present on the current content node as a property that is set via a Media Picker.
So My Macro has an ImageId parameter and looks like this:
Now I can not stop getting this infamous: System.OverflowException: Value was either too large or too small for an Int32.error without checking the Skip Testing checkbox.
As to the template that I am trying to use the macro in, the code looks like this:
Going back to my original problem, now that I am passing the correct imageId to the macro my invocation to GetMedia works and the macro itself does what I wanted it do do.
I guess because I am using the latest version of umbraco the xml schema for the media is a bit different. There are no data nodes and the xml looks like this:
But in my case there is no such information for a media of type Image. Do you think specifying alt text for an image file is possible in umbraco out of the box?
General GetImage macro
<xsl:variable name="imageId" select="/macro/imageId" />
<xsl:template match="/">
<xsl:variable name="media" select="umbraco.library:GetMedia($imageId, 0)" />
<xsl:if test="$media">
<img src="{$media/umbracoFile}" alt="{$media/altText}" />
</xsl:if>
</xsl:template>
<umbraco:Macro imageId="<umbraco:Item field='logo' recursive='true' runat='server'></umbraco:Item>" Alias="GetImage" runat="server"></umbraco:Macro>
Basically set the imageId macro parameter from the umbracoItem and use it to build the image tag.
I get an error: Error parsing XSLT file: \xslt\getImage.xslt
Tried to debug the web site, but it would not build in visual studio due to not being able to find some services and many other errors.
Given a CMS, looks like a simple thing to do, but proves infinitely complicated so far.
Please advise what the problem here is. Hopefully I would not give up umbraco before even starting to use it.
Make one change:
The macro data for media does not return an id.. but instead, returns the xml.
and since media can be any type (Image, Folder, File, etc.) you must reference the type.
You should also be able to get the url without using GetMedia.
Try this:
<img src="{$image/umbracoFile}" />Hi Milen, welcome to the Umbraco community!
As you've already found out, nesting the tags within each other didn't work well.
Here are a couple of things to help you out...
But those require a little more effort... so for a super-quick fix, try this XSLT snippet:
<xsl:variable name="media" select="umbraco.library:GetMedia($imageId, 0)" /> <xsl:if test="normalize-space($media/umbracoFile)"> <img src="{$media/umbracoFile}" alt="{$media/altText}" /> </xsl:if>The reason the XSLT editor is throwing an error is because it must check if the "umbracoFile" has a value first, hence the "normalize-space" call.
Cheers, Lee.
Hi Guys,
Thanks a lot for the replys!
One thing I found out is that passing an to a macro is wrong. All you need to do is pass the page property via the bracket syntax like this:
imageId="[$logo]" Alias="GetImage" runat="server">umbraco:Macro>
The $ is for recrusive properties - quite neat! More information on this I found here:
http://our.umbraco.org/wiki/reference/templates/umbracomacro-element/macro-parameters/advanced-macro-parameter-syntax
The macro looks like this:
The only thing left to figure out is the altText. The documentation in the wiki for the GetMedia function does use an altText node:
http://our.umbraco.org/wiki/reference/umbracolibrary/getmedia
Thanks!
