I'm trying to fetch images from blogposts and and put the lates images on my startpage. I'm using umbraco 4.6.1 and I have some problems regarding GetMedia. here is the code:
the value of mymediapicker is for ex 1093 and there is no problem to print that. When I use mymediapicker in GetMedia I get an xslt error on page. If I replace $mymediapicker with my id 1093 everytihing works fine.
Get media problem
hi
<xsl:variable name="mymediapicker"><xsl:value-of select="./data [@alias='mymediapicker']"/>
</xsl:variable>
<xsl:variable name="media" select="umbraco.library:GetMedia($mymediapicker, 0)" />
<xsl:if test="$media">
<img src="{$media/umbracoFile}" alt="{$media/altText}" />
</xsl:if>
Why can“t I put $mymediapicker in GetMedia?
You have to check either mymediapicker contains value or not.
thats the core issue. When I print out $mymediapicker I do get results but when I use it the GetMedia an xslt error occur on the page...
You can get more details from here http://blog.leekelleher.com/2009/11/30/how-to-use-umbraco-library-getmedia-in-xslt/
thanks!
here is my solution...
please feel free to comment
