  • Milen Kovachev 13 posts 33 karma points
    Mar 26, 2011 @ 07:54
    Milen Kovachev
    GetItem does not return anything?
    I am trying to use the umbraco GetItem function:
        <xsl:variable name="fieldValue" select="umbraco.library:GetItem($currentPage/@id, 'useSimpleHeader')" />
    but it does not return anything although the useSimpleHeader property is on the page I am calling it from.
    Does anyone have an idea where I am going wrong.
    Thanks!
  • Daniel Bardi 927 posts 2562 karma points
    Mar 26, 2011 @ 08:01
    Daniel Bardi
    try this
    <xsl:variable name="fieldValue" select="$currentPage/useSimpleHeader"/>
    Mar 26, 2011 @ 09:45
    Hi Milen
    You should fetch the value like Daniel is showing you above. Are there any specific reason why you're trying to use GetItem?
    If I remember correctly GetItem is handy when you need to output content from a rich text editor where there have been placed a macro. In order to get the content from the macro rendered properly you need to use the "GetItem" extension. Not sure how it's supposed to work on other datatypes...
    Mar 26, 2011 @ 22:58
    Milen Kovachev
    Yes GetItem is certainly not the one I need to use.
    And
    does the trick. If I looked at the raw xml in the database for the current node (page) I would have seen that.
    Thanks for the replies!
