The reason it's not showing the startpage is the XPath in the for-each loop is selecting the Startpage (ancestor-or-self::* [@level=1]), then selecting all nodes beneath it (/* ...)
I think most people typically add in their "start page" link manually, before the for-each loop, since the URL is usually just "/". Example:
Newbie - navigation issue
Hi -
Playing with my first Umbraco install. I have a navigation structure like:
-Startpage
--About
--Services
--Contact
And so on.
Using the Xslt "navigation by level" template I cant get the Startpage to show up in navigation menu.
The other menu items show just fine.
Any idea on how I can also show "Startpage" ?
Code from template;
<!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> ]>
<xsl:stylesheet
version="1.0"
<!-- Input the documenttype you want here -->
<xsl:variable name="level" select="1"/>
<xsl:template match="/">
<!-- The fun starts here -->
<ul>
<xsl:for-each select="$currentPage/ancestor-or-self::* [@level=$level]/* [@isDoc and string(umbracoNaviHide) != '1']">
<li>
</a>
</li>
</xsl:for-each>
</ul>
</xsl:template>
</xsl:stylesheet>
Kind r
Bjørn.
Ho Bjørn,
Hope this helps,
Tom
Hi -
That worked. So easy. Thank you :)
