  • vaibhav 119 posts 139 karma points
    Apr 15, 2011 @ 10:55
    vaibhav
    Problem with package.
    hi,
    I have created package using this guide .......
    http://www.bayshield.com/2010/1/4/creating-a-package-in-umbraco
    But when i install my package to some other machine then it shows some error ...
    error is ....
    Conversion failed when converting the nvarchar value 'Solutions' to data type int.
    Exception Details: System.Data.SqlClient.SqlException: Conversion failed when converting the nvarchar value 'Solutions' to data type int.
    Source Error:
    Stack Trace:
    [SqlException (0x80131904): Conversion failed when converting the nvarchar value 'Solutions' to data type int.]
       System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection) +404
       System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning() +412
       System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj) +1363
       System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString) +6312253
       System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async) +6313986
       System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, DbAsyncResult result) +538
       System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(DbAsyncResult result, String methodName, Boolean sendToPipe) +689
       System.Data.SqlClient.SqlCommand.ExecuteNonQuery() +327
       Microsoft.ApplicationBlocks.Data.SqlHelper.ExecuteNonQuery(String connectionString, CommandType commandType, String commandText, SqlParameter[] commandParameters) +167
       umbraco.DataLayer.SqlHelper`1.ExecuteNonQuery(String commandText, IParameter[] parameters) +150
    [SqlHelperException: Umbraco Exception (DataLayer): SQL helper exception in ExecuteNonQuery]
       umbraco.DataLayer.SqlHelper`1.ExecuteNonQuery(String commandText, IParameter[] parameters) +261
       umbraco.cms.businesslogic.datatype.DefaultData.set_Value(Object value) +1229
       umbraco.cms.businesslogic.web.Document.Import(Int32 ParentId, User Creator, XmlElement Source) +1644
       umbraco.cms.businesslogic.packager.Installer.InstallBusinessLogic(Int32 packageId, String tempDir) +3850
       umbraco.presentation.developer.packages.Installer.processInstall(String currentStep) +1161
       umbraco.presentation.developer.packages.Installer.Page_Load(Object sender, EventArgs e) +573
       System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +25
      umbraco.BasePages.BasePage.OnLoad(EventArgs e) +19
       System.Web.UI.Control.LoadRecursive() +71
       System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +3048
    Can any 1 help me solve possible problems.....
