  • Simon steed 378 posts 700 karma points
    Apr 19, 2011 @ 22:01
    Simon steed
    Big problem with navigation on multilingual site - strange redirection happening
    I've got a site that was initially just in English but is now German as well. The DE part is yet to go live but the UK is still running.
    Previously the structure for the site was:
    Content
    Home
    product
    solution
    help
    Now it's:
    Content
    Home
    product
    solution
    help
    Haus
    German product
    German solution
    German help
    Obviously the only difference is the addition of the German node which was cloned from UK Home. I'm using hostname redirection and that is working okey dokey, however not 100%.
    What is happening now is that the top menu nav is being generated via XSLT (see code below) and when the user clicks upon the link, some strange redirection is happening so instead of seeing:
    http://www.site.com/product they are getting redirected to http://www.site.com/home/product which is messing things up.
    However, if you type in http://www.site.com/product, you do go to the correct page and it all renders fine, just gets redirected and adds the /home to the url - WHY?
    Menu code:
    <xsl:for-each select="$currentPage/ancestor-or-self::* [@isDoc and @level=$level]/* [@isDoc and string(umbracoNaviHide) != '1']">
              <li>
              <!-- Add the class selected if the currentpage or parent nodes (up the tree to the root) ID matches our current node ID in the for each loop-->
              <xsl:if test="$currentPage/ancestor-or-self::* [@isDoc]/@id = current()/@id">
                <xsl:attribute name="class">
                  <xsl:text>selected</xsl:text>
                </xsl:attribute>
              </xsl:if>
                <a>
                <xsl:attribute name="href">
                  /<xsl:value-of select="@urlName" />
                </xsl:attribute>
                  <xsl:value-of select="@nodeName" />
                </a>
                <!-- this does the same, commented out so you can see both approaches
              </a>-->
            </li>
          </xsl:for-each>
    Can anyone suggest what is going on here and how I can resolve it?
    Cheers
    Si
    Apr 21, 2011 @ 18:14
    Simon steed
    Anyone?
  • Berto 105 posts 177 karma points
    Apr 21, 2011 @ 19:39
    Berto
    Do you have the appSetting umbracoHideTopLevelNodeFromPath in the web.config set to true?
    Apr 21, 2011 @ 19:58
    Simon steed
    Spot on - It was set to false, now i've set to true it's now working, thanks big time Berto :-)
    Apr 21, 2011 @ 21:02
    Berto
    Glad i could help ;)
