  • jivan thapa 194 posts 681 karma points
    May 02, 2011 @ 15:09
    jivan thapa
    retrieve macro value using Xslt problem
    I created macro parameter.
    In NewsList.xslt
    ... I interted that macro in Content Page. i also provide parameters value 5 in content page. ....
    But When i try to retrieve macro value, value its empty.
    if we look currentPage there is macro value .
    You can see:
    1) Macro value: is empty
    2) Curent page. numberofnewsitems="5"
    3) copy of : is empty..
    how to solve that problem?
    umbraco version 4.7
    thanks.
  • Michael Latouche 504 posts 819 karma points MVP 4x c-trib
    May 02, 2011 @ 15:40
    Michael Latouche
    Hi Jeevan,
    Have you tried changing the parameter alias name to all lower-case? I had a similar issue, and changing the alias name to all lower-case solved it. I hope it does in your case too :-)
    Michael.
    May 02, 2011 @ 20:59
    Kim Andersen
    Hi Jeevan
    I'm pretty sure that the macro aliases are case sensitive just like property alias'es etc. So you need to specify the exact same name as the alias. THis means that you must change your variable to this:
    <xsl:variable name="numberOfNewsItems" select="/macro/numberOfNewsItems" />
    Does this work?
    /Kim A
  • Chriztian Steinmeier 2800 posts 8791 karma points MVP 8x admin c-trib
    May 02, 2011 @ 22:19
    Hi jeevan,
    Because the alias gets passed to the macro as a child element of <macro> it is (as Michael and Kim alludes to) in fact case sensitive (because XML is case sensitive, that is).
    Also: When using the XSLT Visualizer, it's very important you need to wrap stuff you want to debug in a textarea because the visualizer messes with the output (lowercasing as it see fit, etc.).
    /Chriztian
    May 02, 2011 @ 23:12
    Michael Latouche
    To give some more info about the problem I faced: I had initially created a parameter with capital letters in the name, and I used the same name in my xslt. But for some reason, when rendering the macro in RTE, the parameter name was lower-cased bye default, which meant that my xslt variable, like in Kim's example, did not return anything. Like I mentioned, I solved the problem by putting everything small letter: parameter name, xslt variable filter, etc.
    Michael.
    May 03, 2011 @ 00:06
    jivan thapa
    Thank you so much Michael, chiriztian and Kim.
    . it was cas sensitive problem. now its working.
    Jivan
  • Daniel Bardi 927 posts 2562 karma points
    May 04, 2011 @ 01:59
    Daniel Bardi
    Damn.. 1 day too late on this.. I knew the answer.
