  • vaibhav 119 posts 139 karma points
    May 03, 2011 @ 09:24
    vaibhav
    Problem with truncatestring in aslt
    I have this in my xslt
    <div id="newscontentArea">
                  <div id="newscontentHeader"><xsl:value-of select="umbraco.library:ReplaceLineBreaks(contentHeader)" /></div>
                  <div id="newscontentDate"><xsl:value-of select="umbraco.library:ShortDate(@createDate, true(), ' - ')" /></div>
                  <div id="articlecontent"><xsl:value-of select="umbraco.library:TruncateString(umbraco.library:ReplaceLineBreaks(article),72,'')" disable-output-escaping="yes"/>
                      <xsl:if test="string-length(umbraco.library:ReplaceLineBreaks(article) &gt; 72)">  <!-- only show the link if truncated? -->
                           <a href="{umbraco.library:NiceUrl(@id)}">  >> </a>
                      </xsl:if>
    Problem 1 .
    When i see this in browser then i see the <br> tag after & before this
    what to do so that i dont get this <br>
    May 03, 2011 @ 09:40
    Kim Andersen
    Hi vaibhav
    Maybe the 'article' contains some line breaks. Could you try outputting the entire content of article in a textarea like this:
    <textarea>
    <xsl:copy-of select="article" />
    </textarea>
    /Kim A
    May 07, 2011 @ 12:20
    Hi Vaibhav
    Is this online somewhere so we can see the generated output?
    May 11, 2011 @ 22:33
    Kim Andersen
    Hi vaibhav
    Did you ever find a solution to this issue? If you did, could you post it in here so we can see what caused the "error".
    /Kim A
    May 13, 2011 @ 14:15
    vaibhav
    No i dident found the solution for this error......
    May 13, 2011 @ 15:08
    Kim Andersen
    Have you tried the textarea-trick that I mentioned in my first answer?
    /Kim A
