  • Sam 63 posts 126 karma points
    May 09, 2011 @ 08:23
    Sam
    Using Simple Cart and trying to send the cart items in a regular mail
    Hi All, Im using Simple Cart Js to build a product caalogue and checkout, and what i want to achieve is when the user(s) finish adding items to his basket, on checkout process they fill a form and send it directly by mail.
    And retrieve all the basket items + the form fields in the mail.
    As the classes items reference directly in the js, how can I get the html data and send by mail.
    Anyone can help?
    Quite urgent
    Thks
    //Sam
    May 09, 2011 @ 20:02
    Hi Sam
    You should be able to use the umbraco.library:SendMail() extension to achieve this.
    I don't know how you have constructed this but you need to make sure the method is triggered when the form has been submitted.
    I usually do something like this to do it...
    <xsl:choose>
    <xsl:when test="umbraco.library:Request('sent')">
          <!--- Request the stuff from the form that needs to go into the e-mail here -->
         <xsl:value-of select="umbraco.library:SendMail(parametershere)" />
    </xsl:when>
    <xsl:otherwise>
    <form method="post">
         <input type="hidden" name="sent" value="1" />
    <!-- Rest of the form goes here -->
    </form>
    </xsl:otherwise>
    </xsl:choose>
    Is this what you're after? And does it make sense to you?
    May 10, 2011 @ 09:16
    Sam
    Hi Jan,
     Its all about the problem they are discussing in the link below
    http://our.umbraco.org/forum/developers/extending-umbraco/9309-Simple-cart-with-email-checkout
    Have already implement the cart and created a checkout page, where I have a form and a resume of my basket items...I am able to sent the form by mail but not the basket items..think the problem is with the js itself..if you have any clue on how to retrieve the send this items by mail by modifying the js file...
    Thks
    Sam
    May 10, 2011 @ 09:21
    Sam
    I was wondering is there a way to get html content of body tag of a page and send by mail using XSLT....maybe in the umbraco.library codes..??
    May 10, 2011 @ 22:35
    Hi Sam
    How are the basket items stored? In a cookie collection?
    May 11, 2011 @ 08:15
    Sam
    Hi Jan,
    Sorry for late response...yes the items are stores in cookies...is there anyway to retrieve those and send by mail??
    Sam
