  • Vishal G.P 62 posts 122 karma points
    May 18, 2011 @ 16:53
    Vishal G.P
    Macro parameter with richtext possible?
    Hi guys,
    is it possible to have a macro paramter that is of type richtext... I want to use this macro from the editor, so people can insert this macro in a field, but they will need to have the advantages a richtext field...
    thanks in advance..
    May 18, 2011 @ 22:21
    Hi Wiske80
    No it's not possible to use the rich text editor as a parameter for a macro.
    What are you trying to achieve since you want to make use of an RTE as a parameter?
