  • Maarten Boer 61 posts 82 karma points
    May 22, 2011 @ 11:44
    Maarten Boer
    HELP Xslt Macro's not working anymore
    Until Friday last week, my customers site was working just Fine...
    Friday i only intalled the package Doc2Form.
    Now all marcro's stoped working. When i try to save my Xslt's i get the following ERROR
    Error occured
    System.Exception: Unable to load one or more of the types in assembly 'Umbraco.Forms.Core, Version=1.1.0.29822, Culture=neutral, PublicKeyToken=null'. Exceptions were thrown:
    System.IO.FileNotFoundException: Could not load file or assembly 'Umbraco.Forms.References, Version=1.0.10920.32880, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
    at umbraco.BusinessLogic.Utils.TypeFinder.FindClassesMarkedWithAttribute(Assembly assembly, Type attribute)
    at umbraco.BusinessLogic.Utils.TypeFinder.FindClassesMarkedWithAttribute(Type attribute)
    at umbraco.macro.GetXsltExtensionsImpl()
    at umbraco.cms.businesslogic.cache.Cache.GetCacheItem[TT](String cacheKey, Object syncLock, CacheItemPriority priority, CacheItemRemovedCallback refreshAction, CacheDependency cacheDependency, TimeSpan timeout, GetCacheItemDelegate`1 getCacheItem)
    at umbraco.macro.GetXsltExtensions()
    at umbraco.macro.AddMacroXsltExtensions()
    at umbraco.presentation.webservices.codeEditorSave.SaveXslt(String fileName, String oldName, String fileContents, Boolean ignoreDebugging)
    May 22, 2011 @ 12:36
    Maarten Boer
    I think i found the problem....
    After browsing in de /bin/x86 folder i found the following file Umbraco.Forms.Core.DLL
    After removing this file, every thing was working fine again.....
    Is this a remain of one of the installed pakages ???
    Maarten
  • Bo Damgaard Mortensen 719 posts 1207 karma points
    May 23, 2011 @ 00:50
    Hi Maarten,
    What version of Umbraco are we talking here? :-)
    May 23, 2011 @ 07:24
    Maarten Boer
    Hi Bo,
    I have to add the following: I installed Contour first and to test and removed the package and then Doc2Form.
    Im running Umbraco 4.7 clean installation, no upgraded version.
    Maarten
