Hey guys
Getting a strange error on, in a for-each.
<xsl:value-of select="umbraco.library:DateGreaterThanToday(./nyhedDatofra)"/>
System.FormatException: String was not recognized as a valid DateTime. at System.DateTimeParse.Parse(String s, DateTimeFormatInfo dtfi, DateTimeStyles styles) at umbraco.library.DateGreaterThanToday(String firstDate)
I have tested the possibilities and this is good
<xsl:value-of select="umbraco.library:DateGreaterThanToday(umbraco.library:GetXmlNodeById(1116)/nyhedDatofra)"/>
and this is bad
<xsl:value-of select="umbraco.library:DateGreaterThanToday(umbraco.library:GetXmlNodeById($id)/nyhedDatofra)"/>
Hope you can help.
Thanks/Johan
Hey guys
<xsl:value-of select="umbraco.library:DateGreaterThanToday(./nyhedDatofra)"/>System.FormatException: String was not recognized as a valid DateTime.
<xsl:value-of select="umbraco.library:DateGreaterThanToday(umbraco.library:GetXmlNodeById(1116)/nyhedDatofra)"/>and this is bad
<xsl:value-of select="umbraco.library:DateGreaterThanToday(umbraco.library:GetXmlNodeById($id)/nyhedDatofra)"/>Hope you can help.
/Johan
