  • sravani 50 posts 70 karma points
    Jun 03, 2011 @ 07:44
    sravani
    3rd level navigation menu??
    Dear All,
    my 2nd level navigation is..
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
      version="1.0"
    <xsl:template match="/">
    <xsl:variable name="items" select="$currentPage/ancestor-or-self::* [@isDoc and @level = 2]/* [@isDoc and string(umbracoNaviHide) != '1']"/>
    <!-- The fun starts here -->
    <xsl:if test="count($items) &gt; 0">
    <ul>
    <xsl:for-each select="$items">
      <li>
     <xsl:attribute name="class">
                  selected
                </xsl:attribute>
        </a>
      </li>
    </xsl:for-each>
    </ul></xsl:if>
    </xsl:template>
    </xsl:stylesheet>
    I need to add sub nodes for 2nd level navigation menu
    like mainmenu1
            .submenu1
                  .submenu1.1
    Any Ideas pls share with me ... Thanks in advance.....
    Regadrs,
    Sravani
