Can we do this?
<xsl:value-of select="number($currServicePageID)"/><a href="{umbraco.library:NiceUrl($currServicePageID)}"></a>
I have a value on $currentServicePageID which could be possibly string so i converted it to number as NiceUrl takes so but this is not working at all.
That should work - what exactly is the problem? Are you getting an error when you try to save?
You might want to add a check to make sure the variable has something in it, ie
<xsl:if test="$currServicePageID > 0"><a href="{umbraco.library:NiceUrl($currServicePageID)}"></a></xsl:if>
Otherwise you can get an error if it's empty or sometimes while saving.
-Tom
Do you receive the error when saving inside Umbraco ?
/Thor
NiceUrl Issue
Can we do this?
-Tom
/Thor
