Hi All
i want to use the rich text editor in template with truncated text. i need the correct syntax for that,
any help !! i tried following syntax, but not working
<umbraco:Item field="columnLeft" runat="server" xsl="umbraco.library:TruncateString({0},100, '...')" xsltDisableEscaping="true" ></umbraco:Item>
thanks
Asim
the xsl= attribute should actually be Xslt=
<umbraco:Item field="columnLeft" runat="server" Xslt="umbraco.library:TruncateString({0},100, '...')" xsltDisableEscaping="true" ></umbraco:Item>
-Tom
Upload image
Inline XSL syntax for Rich text editor truncate string. help!
Hi All
thanks
Asim
-Tom
