  • asim 16 posts 36 karma points
    Jun 09, 2011 @ 08:00
    asim
    Inline XSL syntax for Rich text editor truncate string. help!
    Hi All
    i want to use the rich text editor in template with truncated text. i need the correct syntax for that,
    any help !! i tried following syntax, but not working
    <umbraco:Item field="columnLeft" runat="server" xsl="umbraco.library:TruncateString({0},100, '...')" xsltDisableEscaping="true" ></umbraco:Item>
    thanks
    Asim
    Jun 09, 2011 @ 14:19
    Tom Fulton
    the xsl= attribute should actually be Xslt=
    <umbraco:Item field="columnLeft" runat="server" Xslt="umbraco.library:TruncateString({0},100, '...')" xsltDisableEscaping="true" ></umbraco:Item>
    -Tom
