Its working perfect but problem in I need accordion menu . In this menu parent node and child nodes are dispaly for the first time itself. I need child node display occure when I am selecting the parent node.
If i understand the problem correctly, you could you put an id statement around the second for loop to check if the current node is equaly to the current page. That way the child nodes will only display when you are on the parent.
<xsl:if test="$currentPage/@id = ./@id ">
Does that help of have i missunderstood your problem?
It display corectly but when I am selecting the child node all child node are disappear,
my menu is like
Main menu
. 2nd level node
. 3rd level
.3rd level 1
.3rd level 2
.2nd level 1
. 3rd level
.3rd level 1
.3rd level 2
like that I need to display first time all 2nd level nodes and when I am selecting 2nd level then related 3rd level nodes.
....etc . now I am getting the output like dispaly 2nd level nodes first then selecting 2nd level 3rd level is displaying but when I am selecting 3rd level all 3rd level node are disappear
multi navigation accordion menu
Hi All,
This my code
<xsl:variable name="parentNode" select="$currentPage/ancestor-or-self::*[@isDoc and @level =2]"/>
<xsl:template match="/">
<xsl:if test="count($parentNode/*[@isDoc and string(umbracoNaviHide)!='1']) > 0">
<ul id="secondary-navigation">
<xsl:for-each select="$currentPage/ancestor-or-self::* [@isDoc and @level != 1 and @level != 3 and @level != 4 ]/* [@isDoc and string(umbracoNaviHide) != '1']">
<!--list for selected-->
<li>
<xsl:if test="@id = $currentPage/@id and @level !=1">
<xsl:attribute name="class">selected</xsl:attribute>
</xsl:if>
</a>
<!--Level 4-->
<xsl:if test="count(*[@isDoc and string(umbracoNaviHide)!='1']) > 0">
<ol class="subnav">
<xsl:for-each select="*[@isDoc and string(umbracoNaviHide)!='1']">
<li>
<xsl:if test="@id = $currentPage/@id">
</xsl:if>
</a>
</li>
</xsl:for-each>
</ol>
</xsl:if>
</li>
</xsl:for-each>
</ul>
</xsl:if>
</xsl:template>
</xsl:stylesheet>
Any Ideas? ? pls help me.....
Thanks in advance,
Sravani
Hi Sravani,
L
Thnaks for the reply,
I tried with that also but problem is If I select the child node it will disappear
Regards,
sravani.
ahh of course, if you make it
<xsl:if test="$currentPage/@id = ./ancestor-or-self::*/[@isDoc]/@id ">
that may work.
L
Thanks Again,
my menu is like
Main menu
. 2nd level node
. 3rd level
.3rd level 1
.3rd level 2
.2nd level 1
. 3rd level
.3rd level 1
.3rd level 2
Regards,
sravani
Hey yeah,
Basically you need to do a test before you loop through the children nodes to check if the current page id is equal to any of the children ids.
<xsl:if test="./descendant-or-self::*/@id = $currentPage/@id">
may work, I think
L
Thanks a lot ,
Its working great.....
Regards,
sravani.
