  • Jason Burton 13 posts 33 karma points
    Jun 23, 2011 @ 00:47
    Jason Burton
    Cogworks - Navigation - XSLT issue
    trying to make sure the nodes and child nodes for a selected node tree is selected; The force node isnt working...
    Help?
    Tried setting to 1053 (the ID of "home") so that any other pages wont cause the menu to change..
    Node for Menu
    - Child 1
    - Child 2
    Alternate Links Menu
    - Child 1
    - Child 2
    Seems when I click the alternate menu links, it changes the cognavigation ....
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
    version="1.0"
    <xsl:output method="html" omit-xml-declaration="yes"/>
    <xsl:param name="currentPage" />
    <!--This sets the level that the nav starts at and tells us if we should recurse through child elements-->
    <xsl:variable name="startDepth" select="/macro/startingLevel" />
    <xsl:variable name="recurse" select="/macro/recurse" />
    <xsl:variable name="selectBranches" select="/macro/selectBranches"></xsl:variable>
    <xsl:variable name="maxMenuDepth" select="/macro/maxMenuDepth"></xsl:variable>
    <xsl:variable name="forceNode" select="/macro/forceNode"></xsl:variable>
    <xsl:variable name="walkChildren" select="/macro/expandChildren"></xsl:variable>
    <xsl:variable name="forceHome" select="/macro/forceHome"></xsl:variable>
    <xsl:variable name="securityTrimming" select="/macro/securityTrimming"></xsl:variable>
    <!--Alternate page title variable in here-->
    <!--Styles for the navigation-->
    <xsl:variable name="ulBaseClass" select="/macro/ulBaseClass"></xsl:variable>
    <xsl:variable name="branchClass" select="/macro/branchClass"></xsl:variable>
    <xsl:variable name="selectedClass" select="/macro/selectedClass"></xsl:variable>
    <xsl:variable name="startLevel">
    <xsl:choose>
    <xsl:when test="$startDepth >= 0">
    <xsl:value-of select="$startDepth"/>
    </xsl:when>
    <xsl:otherwise>
    <xsl:value-of select="$currentPage/@level"/>
    </xsl:otherwise>
    </xsl:choose>
    </xsl:variable>
    <!--This calls first iteration of the navigation, sending the first node at the correct depth found in the ancestors of the current page-->
    <xsl:template match="/">
    <xsl:choose>
    <xsl:when test="$forceNode">
    <xsl:variable name="currentNode" select="umbraco.library:GetXmlNodeById($forceNode)"></xsl:variable>
    <xsl:call-template name="nodeIterator">
    <xsl:with-param name="parentNode" select="$currentPage/ancestor-or-self::*[@isDoc][@level=$startLevel]
    string(umbracoNaviHide) != '1'
    and ($securityTrimming != '1'
    or umbraco.library:IsProtected(@id, @path) = false()
    or umbraco.library:HasAccess(@id, @path) = true())
    <xsl:with-param name="pseudoCurrentPage" select="1" />
    </xsl:call-template>
    </xsl:when>
    <xsl:otherwise>
    <xsl:variable name="currentNode" select="$currentPage"></xsl:variable>
    <xsl:with-param name="parentNode" select="$currentNode/ancestor-or-self::*[@isDoc][@level=$startLevel]
    <xsl:with-param name="pseudoCurrentPage" select="$currentNode" />
    </xsl:otherwise>
    </xsl:choose>
    </xsl:template>
    <xsl:template name="nodeIterator">
    <xsl:param name="parentNode" />
    <xsl:param name="pseudoCurrentPage" />
    <!-- do not show info doc node types-->
    <xsl:variable name="calculatedMenuDepth" select="($parentNode/@level - $startLevel) -1" />
    <xsl:if test="$parentNode/*[@isDoc] or ($calculatedMenuDepth = 1 and $forceHome)">
    <ul id='{$ulBaseClass}'>
    <xsl:if test="$forceHome = 1 and $calculatedMenuDepth = 1">
    <!-- Create the class for the li element-->
    <li>
    <xsl:variable name="isHomeSelected">
    <xsl:choose>
    <xsl:when test="$currentPage/ancestor-or-self::*[@isDoc][@level=1]/@id = $currentPage/@id">1</xsl:when>
    </xsl:choose>
    </xsl:variable>
    <xsl:call-template name="cssClassConstructor">
    <xsl:with-param name="isSelected" select="$isHomeSelected" />
    <xsl:with-param name="isSelectedBranch" select="0" />
    <xsl:with-param name="hasChildren" select="1" />
    <xsl:with-param name="selectedClass" select="$selectedClass" />
    <xsl:with-param name="branchClass" select="$branchClass" />
    <a href="{umbraco.library:NiceUrl($currentPage/ancestor-or-self::*[@isDoc][@level=1]/@id)}">
    <xsl:with-param name="hasChildren" select="0" />
    <!--set the innerText for the a element-->
    <xsl:value-of select="$currentPage/ancestor-or-self::*[@isDoc][@level=1]/text()"/>
    <xsl:if test="string($currentPage/ancestor-or-self::*[@isDoc][@level=1]/text()) = ''">
    <xsl:value-of select="$currentPage/ancestor-or-self::*[@isDoc][@level=1]/@nodeName"/>
    </xsl:if>
    </a>
    </li>
    </xsl:if>
    <!--End force home-->
    <!--for each node in the parent node that is not hidden by Umbraco-->
    <xsl:for-each select="$parentNode/*[@isDoc][
    <!--Set the current node id i.e. the node we have looped to not the current page-->
    <xsl:variable name="currentNodeID" select="@id" />
    <!--Is the node a branch? i.e. are there children and is it in the colletion of ancestor nodes -->
    <xsl:variable name="isBranch">
    <xsl:choose>
    <xsl:when test="$currentPage/ancestor-or-self::*[@isDoc][@id = $currentNodeID]/child::*[@isDoc]">1</xsl:when>
    </xsl:choose>
    </xsl:variable>
    <!--Is the node selected? i.e. is it the same as the currentPage node-->
    <xsl:variable name="isSelected">
    <xsl:choose>
    <xsl:when test="$currentPage/@id = $currentNodeID">1</xsl:when>
    <!-- parent selected -->
    <xsl:when test="$pseudoCurrentPage/@id = $currentNodeID">1</xsl:when>
    </xsl:choose>
    </xsl:variable>
    <xsl:variable name="isSelectedBranch">
    <xsl:choose>
    <xsl:when test="$isBranch = 1 and $selectBranches = 1">1</xsl:when>
    </xsl:choose>
    </xsl:variable>
    <xsl:variable name="hasChildren">
    <xsl:choose>
    <xsl:when test="./*[@isDoc]">1</xsl:when>
    </xsl:choose>
    </xsl:variable>
    <li>
    <!-- Create the class attribute for the element-->
    <xsl:with-param name="isSelected" select="$isSelected" />
    <xsl:with-param name="isSelectedBranch" select="$isSelectedBranch" />
    <xsl:with-param name="hasChildren" select="$hasChildren" />
    <xsl:value-of select="./pageTitle/text()"/>
    <xsl:if test="string(./pageTitle/text()) = ''">
    </xsl:if>
    </a>
    <!-- if it's a branch recurse through it's children-->
    <xsl:if test="((($isBranch = 1 and $recurse = 1) or ($walkChildren = 1)) and $maxMenuDepth &gt;= $calculatedMenuDepth)">
    <xsl:with-param name="parentNode" select="." />
    <xsl:with-param name="pseudoCurrentPage" select="$pseudoCurrentPage" />
    </xsl:if>
    </li>
    </xsl:for-each>
    </ul>
    </xsl:if>
    </xsl:template>
    <xsl:template name="cssClassConstructor">
    <xsl:param name="isSelected"></xsl:param>
    <xsl:param name="isSelectedBranch"></xsl:param>
    <xsl:param name="hasChildren"></xsl:param>
    <xsl:param name="selectedClass"></xsl:param>
    <xsl:param name="branchClass"></xsl:param>
    <xsl:variable name="class">
    <xsl:if test="$isSelected = 1">
    <xsl:value-of select="concat($selectedClass,' ')"/>
    </xsl:if>
    <xsl:if test="$isSelectedBranch = 1">
    <xsl:value-of select="concat($branchClass,' ')"/>
    </xsl:if>
    <xsl:if test="$hasChildren = 1">
    <xsl:value-of select="'hasChildren '"/>
    </xsl:if>
    </xsl:variable>
    <xsl:if test="string-length($class) > 0">
    <xsl:attribute name="class">
    <xsl:value-of select="normalize-space($class)"/>
    </xsl:attribute>
    </xsl:if>
    </xsl:template>
    </xsl:stylesheet>
