I have a
problem regarding my XML and self closing tags.
An example is an <img src=”…” /> will be rendered as so <img src=”…”>
- without the close tag “/”
The reason for this is that you have instructed the parser to render HTML instead of XML.
In this linethe output should be changed to xml.
EDIT: This will probably mess up your layout since I suspect the empty <div class="clear"></div> will collapse so in order to make sure that does not happen write it as either <div class="clear"><xsl:text> </xsl:text></div>, which will insert an empty space or use <div class="clear"><xsl:comment /></div>, which will render an html comment like <!-- --> in the output.
Sometimes it's so plain simple to find an answer yourself, which also costs less time than creating/typing this topic. So I thought I'd just point the topicstarter in the right direction. Maybe that'll also help for the next time.
Problem with self closing tags
I have a problem regarding my XML and self closing tags.
An example is an <img src=”…” /> will be rendered as so <img src=”…”> - without the close tag “/”
An example of one macro
<!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> ]>
<xsl:stylesheet
version="1.0"
<xsl:output method="html" omit-xml-declaration="yes" />
<xsl:variable name="level" select="2"/>
<xsl:template match="/">
<xsl:for-each select="$currentPage/ancestor-or-self::* [@level=$level]/* [@isDoc and string(umbracoNaviHide) != '1']">
<div class="divMenuItem">
<div class="divMenuText">
<a style="text-decoration:none" href="{umbraco.library:NiceUrl(@id)}">
<b><xsl:value-of select="@nodeName"/></b>
</a>
<div class="divMenuSeperator">
<img alt="seperator" src="/media/2294/menuseperator.png" />
</xsl:for-each>
</xsl:template>
</xsl:stylesheet>
Regards Martin
Hi Martin
Hope this helps.
Really hard to search indeed :-/
http://www.google.com/search?q=umbraco+xslt+self+closing
First hit: http://our.umbraco.org/wiki/how-tos/xslt-useful-tips-and-snippets/stop-html-tags-from-self-closing
@Kip: Remember...this is the most friendly community... :-)
Yes it is, and I was not being non-friendly ;-)
Cool, maybe I just read it wrong :)
Regarding the http://our.umbraco.org/wiki/how-tos/xslt-useful-tips-and-snippets/stop-html-tags-from-self-closing link - i read it.
Ive tried
<xsl:text disable-output-escaping="yes"><img alt="seperator" src="/media/2294/menuseperator.png"/></xsl:text>
<xsl:text disable-output-escaping="yes"><![CDATA[<img alt="seperator" src="/media/2294/menuseperator.png" />]]></xsl:text>
Didnt do the trick
@Jan - Thanks for the <div class="clear"><xsl:comment /></div>... now the menu dosnt collapse when useing the output mothod = "xml"
Hi Martin
Happy to hear you got it working :-)
Please mark the post as solved so others can also benefit from the solution.
Have a great day.
Or, like the link suggests, use a non breaking space: <divclass="clear"> </div>
