  • Jamie 35 posts 87 karma points
    Jul 13, 2011 @ 11:10
    Jamie
    Using variable in a concatenation in XSLT
    I'm needin umbraco to build an XML formatted document for a flash movie that is loading in variables via a fixed url (as in I do not have access to the source to chnage it).  I have most of it work however the only way I could get umbraco to output <![CDATA[  ]]> was to use concatination.
    This works fine for a value comming from the 'doctype' proprties
    <img><xsl:value-of  select="concat('&lt;![CDATA[x',image,']]&gt;')" disable-output-escaping="yes"/></img>
    outputs <img><![CDATA[0]]></img> the input in the doctype is a true/false.
    But if I try and define a variable it does not work .
    <xsl:variable name="imageurl" select="/assets/test.jpg"/>
    <img><xsl:value-of  select="concat('&lt;![CDATA[x',$imageurl,']]&gt;')" disable-output-escaping="yes"/></img>
    outputs <img><![CDATA[]]></img> so no data.
    I can't seem to figure out why this is.. any ideas? Is thier somehtign special I need to do when including a variable in a concatinated string?
    Jul 13, 2011 @ 12:26
    Hi Jamie
    Try doing this instead
    <img><xsl:text disable-output-escaping="yes"><![CDATA[</xsl:text> <xsl:value-of select="$imageurl" /> <xsl:text disable-output-escaping="yes">]]></xsl:text></img>
    Hope this helps.
  • Chriztian Steinmeier 2800 posts 8791 karma points MVP 8x admin c-trib
    Jul 13, 2011 @ 13:20
    Hi Jamie,
    The reason your $imageurl doesn't work, is that where you think you're specifying a string, you're actually specifying an XPath, so it's trying to set the variable to the value of the <test.jpg> element inside the root element <assets> ! :-)
    You just need to wrap it in single quotes to specify a string:
    <xsl:variable name="imageurl" select="'/assets/test.jpg'" />
    To output CDATA you really should be using the cdata-section-elements attribute on the xsl:output element, e.g:
     <xsl:output cdata-section-elements="img" />
    Which will make sure that everytime an <img> element is generated by the XSLT processor, it'll wrap its contents in a CDATA Section and make sure that its contents is escaped correctly.
    /Chriztian
    Sep 19, 2011 @ 11:15
    Jamie
    Jan solved my immidate problem.
    Christian though showed me the better way to do this .. which what my secret hope in asking the question as I could find nothign on CDATA and umbraco XSLT at the time.
    [sorry this wasn't marked as such at the time thoguht I had give a more robust thank you but it appears not to have saved / submitted.]
