  • praveen 113 posts 164 karma points
    Jul 19, 2011 @ 04:15
    praveen
    UMBRACO 4.7 Top Navigation
    Hi there,
    I have this macro in the Master Template:
           <umbraco:Macro Alias="TopNavigation" runat="server"></umbraco:Macro>
    and this is the XSLT code
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
    version="1.0"
    <!-- Input the documenttype you want here -->
    <!-- Typically '1' for topnavigtaion and '2' for 2nd level -->
    <!-- Use div elements around this macro combined with css -->
    <!-- for styling the navigation -->
    <xsl:variable name="siteRoot" select="$currentPage/ancestor-or-self::root" />
    <xsl:template match="/">
    <!-- The fun starts here -->
    <ul>
    <xsl:for-each select="$siteRoot/* [@isDoc and string(umbracoNaviHide) != '1']">
    <li>
    <xsl:if test="$currentPage/ancestor-or-self::*/@id = current()/@id">
    <!-- we're under the item - you can do your own styling here -->
    <xsl:attribute name="class">active</xsl:attribute>
    </xsl:if>
    <xsl:if test="count($siteRoot/* [@isDoc and string(umbracoNaviHide) != '1']) = position()">
    <xsl:attribute name="class">last</xsl:attribute>
    </xsl:if>
    <xsl:if test="$currentPage/ancestor-or-self::*/@id = current()/@id and count($siteRoot/* [@isDoc and string(umbracoNaviHide) != '1']) = position()">
    <xsl:attribute name="class">last active</xsl:attribute>
    </xsl:if>
    </a>
    </li>
    </xsl:for-each>
    </ul>
    </xsl:template>
    </xsl:stylesheet>
    But I cant get the menu rendered on the page, please help
    Kind Regards
    Praveen
  • Fuji Kusaka 2203 posts 4220 karma points
    Jul 19, 2011 @ 05:23
    Fuji Kusaka
    Hi Praveen, can you should us your Content Structure?
    Or you can try change this
    <ul>
    <li>
    </xsl:if>
    </xsl:if>
    </xsl:if>
    </a>
    </li>
    </xsl:for-each>
    </ul>
    to
    <xsl:variable name="level" select="1"/>
    <ul>
    <xsl:for-each select="$currentPage/ancestor-or-self::* [@level=$level]/* [@isDoc and string(umbracoNaviHide) != '1']">
      <li>
          </xsl:if>
           <xsl:if test="position()=last()">
           </xsl:if>
        </a>
      </li>
    </xsl:for-each>
    </ul>
    //Fuji
    Jul 19, 2011 @ 06:25
    praveen
    Hi Fuli
    Many thanks for your help, my menu looks like this, its quite simple
    Home | Resources | Contact | Other Links | Other Resources | NZ FGM Programme
    I have changed the XSLT as advised, see below, but it still dose not work??
    <xsl:stylesheet
    version="1.0"
    <xsl:variable name="level" select="1"/><xsl:template match="/">
    <ul>
        <li>
            </xsl:if>
            </xsl:if>
            <xsl:value-of select="@nodeName"/>    </a>
         </li>
         </xsl:for-each>
    </ul>
    </xsl:template>
    </xsl:stylesheet>
    Jul 19, 2011 @ 08:06
    Fuji Kusaka
    Praveen can you send us a screenshot of your content node?....I just check the XSLT and its working, are all the nodes under the same level as your default node such as
    Content
    - Default(home)
    --  Resources
    --- Contact
    --- Other Links
    --- Other Resources
    --- NZ FGM Programme
    //fuji
    Jul 20, 2011 @ 00:12
    praveen
    Hi Fujji
    Many thanks for your help :)
    Please find the content screen shot, the nodes which are highlighted are ment to be hidden from the top menu  "Hide From Menus"
    after installing 4.7 I have not installed any packages on top of this, do I need to install something for the Top Navigation to work?
    Jul 20, 2011 @ 05:28
    Fuji Kusaka
    Hi Praveen,
    There is no need to install any package to be able to view your Top Navigation. Just used the macro you previously created. From your screenshot, i would suggest you to move your innerpages (nodes) starting from Resources to Complicationsfgm like the example below.
    One way of doing this since you already created your content is Settings > Choose Homepage Document Type > Click Structure Tab > Check for the InnerPage Document Type.and Save.
    Go back to your Content section, right click on one your node and choose Move and Select Home node.
    Try with the first node Resources and see if your Top Navigation is showing up and carry one with the other nodes.
    //fuji
    Jul 20, 2011 @ 07:05
    praveen
    Hi Fuji many thanks I did what you recommended but it still dose not help
    Setting Screen Shot
    Content Tab
    Jul 20, 2011 @ 07:31
    Fuji Kusaka
    Praveen thats weird but you should be able to view your navigation by now. Try one last thing, create another XSLT Files and choose List Sub Pages By Level and insert it in your template.
    Give this a try and let me know what is the output. You might need to change your
    <xsl:variable name="level" select="2"/>
    to
    Let me know if you are getting any output
    Jul 20, 2011 @ 08:59
    praveen
    HI Fuji
    I  have set the UseLegacyXmlSchema to FALSE is this the cause of the problem
    I am not able to get the search work as well, I have used the XSLTsearch 3.0 package?
    if you give me your email I can send the password to the site you can log in and see what the problem is.
    Praveen
    Jul 20, 2011 @ 09:17
    Fuji Kusaka
    I would suggest you set it back to true!! Here is my email drop me a mail [email protected]
    //fuji
    Jul 20, 2011 @ 12:04
    praveen
    HI Fuji
    I sent you the mail, lookforward to hear from you
    Regards
    Praveen
    Jul 20, 2011 @ 12:12
    Fuji Kusaka
    Ill have a look at it.
    Jul 20, 2011 @ 20:02
    Fuji Kusaka
    Hey Praveen i had a quick look to your search and seems to be working fine. Try to add some more fields in your searchFields macros to make your search more efficient.
    //fuji
    Jul 21, 2011 @ 07:45
    Fuji Kusaka
    Praveen under Home Document Type  > Click on Strucutre Tab and Checked Related Document Type (Allowed child nodetypes) to be able to create new node under your Home Node.
    //fuji
    Jul 22, 2011 @ 00:17
    praveen
    HI Fuji
    Many thanks for your help, it did work!
    Regards
    Praveen
    Jul 22, 2011 @ 05:21
    Fuji Kusaka
    great if you got it working.
    //fuji
