  • vaibhav 119 posts 139 karma points
    Jul 21, 2011 @ 10:17
    vaibhav
    problem with truncate string
    I want to truncate the string ... & string should show ">>" at the end of string......
    if i use this .....<xsl:value-of select="umbraco.library:TruncateString($currentPage/ancestor-or-self::*[@isDoc]/c1block1_Content, 120,' >>')" disable-output-escaping="yes"/>
    then it only shows ">>" if string characters are more than 120 , which i dont want....
    if i use <xsl:value-of select="umbraco.library:TruncateString($currentPage/ancestor-or-self::*[@isDoc]/c1block1_Content, 120,' ')" disable-output-escaping="yes"/>  >>
    thenit shows ">>" in next line...
    if i see view source then it shows something like this...it automatically creates <p></p> tags....
    <p>string</p> >>
    how to solve this....
