  • Allan49 35 posts 55 karma points
    Aug 02, 2011 @ 17:12
    Allan49
    Is there any way to test/develop XSLTs outside Umbraco?
    I have rich set of xslt development and debugging tools. Is there any way to test xslts outside Umbraco?
    I am hoping to get the test XML data somehow so I can use them as test data to develop my xslts.
    Thank you,
  • Chriztian Steinmeier 2800 posts 8791 karma points MVP 8x admin c-trib
    Aug 02, 2011 @ 23:13
    Hi Allan49,
    There are several ways to get to the XML:
    - First of all, it's stored as flat file on the disk in /App_Data/umbraco.config
    - Second, you can use a package called XMLDump to investigate and copy parts/all of the tree (does Media nodes too)
    - Lastly, you can do ainside a textarea, to dump the XML to the page you're on
    Regarding "outside" development - I do that 98% of the time (I prefer TextMate on a Mac) but that requires some discipline, and it'll be *much* easier with the so-called "match templates" approach. I wrote about some of the issues in this article (though, I'd recommend you read them all :-)
    /Chriztian
