  • vaibhav 119 posts 139 karma points
    Aug 12, 2011 @ 08:44
    vaibhav
    problem in applying link
    I am having one node & its sub nodes something like this....
    Node
    >>Node1
         >>Node1SubNode1
         >>Node1Subnode2
         >>Node1Subnode3
    >>Node2
         >>Node2SubNode1
         >>Node2Subnode2
         >>Node2Subnode3
    Here i am showing data of the Node1SubNode1 , Node1SubNode2 , Node1SubNode3 , Node2SubNode1 , Node2Subnode2 , Node2Subnode3  in the node page.
    I am able to show the text & image but link which i apply to the text is not appearing properly ....
    wats wrong i m doing .....Here is my xslt code which shows all above node in the list in mmain node....
    <xsl:template match="/">
        <xsl:for-each select="$currentPage/*[@isDoc and string(umbracoNaviHide) != '1']">
          <br/>
       <div id="pubSection">
         <div id="pubSectionHeader">
          <xsl:for-each select="././*[@isDoc]">
            <div id="pubArticle">
              <div id="pubImage"><img src="{./pubThumbnail}" alt="" width="115px" height="90px"/></div>
              <div id="pubContentArea">
              <div id="pubHeader"><xsl:value-of select="pubHeader"/></div>
                <div id="pubContent"><a href="{pubSelectfile}"><xsl:value-of select="umbraco.library:TruncateString(umbraco.library:ReplaceLineBreaks(pubContent),190,'')"/> >> </a>
             </xsl:for-each>
         </xsl:for-each>
    </xsl:template>
    pubSelectfile is alias of the upload control where i will select the some pdf file ....this pdf file will oopen when i click on the text ....
    can any one help me .....
  • Fuji Kusaka 2203 posts 4220 karma points
    Aug 12, 2011 @ 08:59
    Fuji Kusaka
    Hi Vaibhav,
    From what i understand is that you have an upload field for your pdf? If you can try to check first if any pdf file has been uploaded.
    Try changing
    <ahref="{pubSelectfile}"><xsl:value-ofselect="umbraco.library:TruncateString(umbraco.library:ReplaceLineBreaks(pubContent),190,'')"/>>> </a>
    <xsl:variable name="pdfFile" select="pubSelectfile" />
     <xsl:if test="$pdfFile!= ''">
                  <a target="_blank">
                    <xsl:attribute name="href">
                       <xsl:value-of select="pubSelectfile"/>
                    </xsl:attribute><xsl:value-ofselect="umbraco.library:TruncateString(umbraco.library:ReplaceLineBreaks(pubContent),190,'')"/>>>
                </a>
     </xsl:if>
    Hope this helps
    Aug 12, 2011 @ 09:32
    vaibhav
    Thanx Fuji ...it wworked for me ....
    Aug 12, 2011 @ 09:34
    Fuji Kusaka
    No worries....good to hear you got it working
    //fuji
