Hi All,
I have the following XSLT code:
<?xml version="1.0" encoding="UTF-8"?><!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> ]><xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:msxml="urn:schemas-microsoft-com:xslt" xmlns:umbraco.library="urn:umbraco.library" xmlns:Exslt.ExsltCommon="urn:Exslt.ExsltCommon" xmlns:Exslt.ExsltDatesAndTimes="urn:Exslt.ExsltDatesAndTimes" xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath" xmlns:Exslt.ExsltRegularExpressions="urn:Exslt.ExsltRegularExpressions" xmlns:Exslt.ExsltStrings="urn:Exslt.ExsltStrings" xmlns:Exslt.ExsltSets="urn:Exslt.ExsltSets" exclude-result-prefixes="msxml umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings Exslt.ExsltSets "><xsl:output method="xml" omit-xml-declaration="yes"/><xsl:param name="currentPage"/><xsl:template match="/"><xsl:for-each select="$currentPage/ancestor-or-self::* [name()='Event' and umbraco.library:DateGreaterThanOrEqualToday(./eventDate)]"><div class="event_1_main"> <div class="event_img"><img src="/images/event_img_2.jpg" alt="" /></div> <div class="event_right_part"> <h2 class="event_title"><xsl:value-of select="current()/@nodeName"/></h2> <div class="event_text"> <strong><xsl:value-of select="current()/eventDate"/></strong><br /> <xsl:value-of select="current()/eventDescription"/> </div> <div class="viewmore_btn"><a href="{umbraco.library:NiceUrl(current()/@id)}">VIEW MORE</a></div> </div></div></xsl:for-each></xsl:template></xsl:stylesheet>
and it displays nothing on my page. What is the correct way to select child elements of the current page by type?
I will also need to perform a similar selection in another piece of code, so how does one select elements from under a specific node?
Hi Geoff,
Try this slight refactoring for a simple way to illustrate this:
<xsl:template match="/"> <xsl:apply-templates select="$currentPage/ancestor-or-self::Event[umbraco.library:DateGreaterThanOrEqualToday(eventDate)]" /> </xsl:template> <!-- Template for an Event node --> <xsl:template match="Event"> <div class="event_1_main"> <div class="event_img"> <img src="/images/event_img_2.jpg" alt="" /> </div> <div class="event_right_part"> <h2 class="event_title"> <xsl:value-of select="@nodeName"/> </h2> <div class="event_text"> <strong> <xsl:value-of select="eventDate"/> </strong> <br /> <xsl:value-of select="eventDescription"/> </div> <div class="viewmore_btn"> <a href="{umbraco.library:NiceUrl(@id)}">VIEW MORE</a> </div> </div> </div> </xsl:template>
Note that once you're inside a template (or a for-each for that matter) you can just refer to child elements without any prefix (current() or ./ etc.) at all.
/Chriztian
Alright, thanks for your help.
I'm having trouble getting an image to display in this loop.
<img src="{umbraco.library:GetMedia(current()/eventImage, true())}" alt="" />
Gives me "/media/15926/banner.jpg67326887970jpg" - "67326887970jpg" should not be there. What am I doing wrong?
Thanks.
Seems like you are picking the image from the media secion. You could try this chaging this
<imgsrc="{umbraco.library:GetMedia(current()/eventImage, true())}"alt=""/>
to
<img src="{umbraco.library:GetMedia(eventImage, 'true')/umbracoFile}" alt=""/>
//fuji
Looping and page selection in XSLT problem
Hi All,
<xsl:stylesheet
version="1.0"
</xsl:for-each>
</xsl:template>
</xsl:stylesheet>
Hi Geoff,
<xsl:template match="/"> <xsl:apply-templates select="$currentPage/ancestor-or-self::Event[umbraco.library:DateGreaterThanOrEqualToday(eventDate)]" /> </xsl:template> <!-- Template for an Event node --> <xsl:template match="Event"> <div class="event_1_main"> <div class="event_img"> <img src="/images/event_img_2.jpg" alt="" /> </div> <div class="event_right_part"> <h2 class="event_title"> <xsl:value-of select="@nodeName"/> </h2> <div class="event_text"> <strong> <xsl:value-of select="eventDate"/> </strong> <br /> <xsl:value-of select="eventDescription"/> </div> <div class="viewmore_btn"> <a href="{umbraco.library:NiceUrl(@id)}">VIEW MORE</a> </div> </div> </div> </xsl:template>Note that once you're inside a template (or a for-each for that matter) you can just refer to child elements without any prefix (current() or ./ etc.) at all.
/Chriztian
<img src="{umbraco.library:GetMedia(current()/eventImage, true())}" alt="" />Gives me "/media/15926/banner.jpg67326887970jpg" - "67326887970jpg" should not be there. What am I doing wrong?
Thanks.
Hi Geoff,
<imgsrc="{umbraco.library:GetMedia(current()/eventImage, true())}"alt=""/>to
<img src="{umbraco.library:GetMedia(eventImage, 'true')/umbracoFile}" alt=""/>//fuji
