This may sound repetitive..but is there a way to call a macro inside of your xslt? Specifically, I'm trying to reference a usercontrol from within my xslt.
Appologies - I have a hard time sometimes with the search on the forums. You have to be very vague in your search query and then sort through lots of results that may not have anything to do with what you are looking for.
I have another way to do this, but I was just wondering. Thanks!
Place macro inside of xslt
Hi kaifish,
If you search the forum, you'll find a lot about this - but you can not render a Usercontrol Macro from within an XSLT macro (last time I checked).
You'll probably find some good suggestions to alternate ways of doing what you need.
/Chriztian
