  • Alexey Shevchenko 15 posts 34 karma points
    Aug 30, 2011 @ 14:05
    Alexey Shevchenko
    Multi-level menu
    Hi all. I'm beginner in Umbraco CMS.
    Now I'm doing my first site, and I've met a problem. I made search on forum and find that I am not first who asked how to solve such issue. But even using existing examples I can't  cope.
    So I have such site's structure:
    - Company profile
      - cp_sub1
      - cp_sub2
      - cp_sub3
    - Eco taxe
      - et_sub1
      - et_sub2
    - Road network
      - rn_sub1
      - rn_sub2
    For formation of top menu I use umbTopNavigation.xslt. I want to rewrite this xslt so that this xslt creates such html:
    <tr>
    <td id="ListViewMenu_MenuItem_0" class="item item-with-popup">
    <a href="/Company/" id="ListViewMenu_MenuItemHref_0">
    <div class="item-text">Company profile</div>
    </a>
    <div class="underline">Company profile</div>
    <div class="popup-panel-border">Company profile</div>
    <div class="popup-panel">
    <div class="sub-menu">
    <a href='/Company/cp_sub1.aspx'>
    <div>cp_sub1</div>
    </a>
    <a href='/Company/cp_sub2.aspx'>
    <div>cp_sub2</div>
    </a>
    <a href='/Company/cp_sub3.aspx'>
    <div>cp_sub3</div>
    </a>
    </td>
    <a href="/EcoTaxe/" id="ListViewMenu_MenuItemHref_1">
    <div class="item-text">Eco taxe</div>
    </a>
    <div class="underline">Eco taxe</div>
    <div class="popup-panel-border">Eco taxe</div>
    <a href='/EcoTaxe/et_sub1.aspx'>
    <div>et_sub1</div>
    </a>
    <a href='/EcoTaxe/et_sub2.aspx'>
    <div>et_sub2</div>
    </a>
    </td>
    <a href="/RoadNetwork/" id="ListViewMenu_MenuItemHref_2">
    <div class="item-text">Road network</div>
    </a>
    <div class="underline">Road network</div>
    <div class="popup-panel-border">Road network</div>
    <a href='/RoadNetwork/rn_sub1.aspx'>
    <div>rn_sub1</div>
    </a>
    <a href='/RoadNetwork/rn_sub2.aspx'>
    <div>rn_sub2</div>
    </a>
    </td>
    </tr>
    I've google for a day, found many examples, but alas still can't solve this issue.
  • dwarakesh 50 posts 69 karma points
    Aug 30, 2011 @ 14:37
    dwarakesh
    just use these XSLT.
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
     version="1.0"
     xmlns:umbraco.library="urn:umbraco.library" xmlns:Exslt.ExsltCommon="urn:Exslt.ExsltCommon" xmlns:Exslt.ExsltDatesAndTimes="urn:Exslt.ExsltDatesAndTimes" xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath" xmlns:Exslt.ExsltRegularExpressions="urn:Exslt.ExsltRegularExpressions" xmlns:Exslt.ExsltStrings="urn:Exslt.ExsltStrings" xmlns:Exslt.ExsltSets="urn:Exslt.ExsltSets" xmlns:tagsLib="urn:tagsLib" xmlns:BlogLibrary="urn:BlogLibrary"
     exclude-result-prefixes="msxml umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings Exslt.ExsltSets tagsLib BlogLibrary ">
    <!-- Input the documenttype you want here -->
    <!-- Typically '1' for topnavigtaion and '2' for 2nd level -->
    <!-- Use div elements around this macro combined with css -->
    <!-- for styling the navigation -->
    <xsl:variable name="level" select="1"/>
    <xsl:template match="/">
    <ul >
      <xsl:for-each select="$currentPage/ancestor-or-self::* [@level=$level]/* [@isDoc and string(umbracoNaviHide) != '1']">
      <li>
        <a href="{umbraco.library:NiceUrl(@id)}"><xsl:value-of select="@nodeName"/></a>
        <!-- Drop Down Menu -->
        <xsl:if test="count(./* [@isDoc and string(umbracoNaviHide) != '1']) &gt; 0">
           <ul>
             <xsl:for-each select="./* [@isDoc and string(umbracoNaviHide) != '1']">
                 <li>
                   <a href="{umbraco.library:NiceUrl(@id)}"><xsl:value-of select="@nodeName"/></a></li>
             </xsl:for-each>
           </ul>
        </xsl:if>
      <!-- End of Drop Down Menu -->
      </li>
      </xsl:for-each>
      </ul>
    </xsl:template>
    </xsl:stylesheet>
    Aug 30, 2011 @ 15:27
    Alexey Shevchenko
    Thank You! It really works=)
