  • Stephen 204 posts 246 karma points
    Aug 31, 2011 @ 12:45
    Stephen
    Display on level and parent alias
    Hi All,
    I have a subnav that dsiplays when its level 2 as show below..works well
    <!DOCTYPE xsl:stylesheet [
        <!ENTITY nbsp "&#x00A0;">
    <xsl:stylesheet
      version="1.0"
        <xsl:template match="/">
          <xsl:if test="$currentPage/parent::* [@level >= 2]" >
            <xsl:variable name="parentNode" select="$currentPage/parent::* [@isDoc]"/>
              <a href="{umbraco.library:NiceUrl($parentNode/@id)}">
                ...back to <xsl:value-of select="$parentNode/@nodeName"/>
            </a>
          </xsl:if>
        </xsl:template>
    </xsl:stylesheet>
    I  now have a requirement for displaying when level 2 but NOT when the parent node is of an alias "tmFolder" as it has not content and is only there to containt the sub pages...
    I'm using the following but not wokring..
    <xsl:stylesheet
      version="1.0"
          <xsl:if test="$currentPage/parent::* [@level >= 2 and $currentPage/parent != 'tmFolder']" >
            </a>
          </xsl:if>
        </xsl:template>
    </xsl:stylesheet>
    Thanks for listening.
    S
  • Rasmus Berntsen 215 posts 253 karma points c-trib
    Aug 31, 2011 @ 16:47
    Rasmus Berntsen
    So what you're doing at the moment in your xsl:if is to test if the node below the currentpage, with the alias parent, is not equal to tmFolder. You want to look at the parent of currentpage and check that the alias of that is not tmFolder.
    Take a look here for XPATH: http://our.umbraco.org/wiki/reference/xslt/xpath-axes-and-their-shortcuts - You'll need this to get the ancestor (parent node)
    And take a look here for how to test on node aliases: http://our.umbraco.org/wiki/reference/xslt/45-xml-schema/no-more-@nodetypealias - You'll need this to test for the nodes alias.
    Let me know if this is enough help or I'll try to look into it. :)
    Edit: Fixed spelling
