  • skiltz 501 posts 701 karma points
    Sep 01, 2011 @ 23:13
    skiltz
    using ":" in xslt attribute.
    Trying to do the following.
    <a class="addthis_counter addthis_pill_style">
    <xsl:attribute name="addthis:url">
    <xsl:value-of select="umbraco.library:NiceUrl($post/@id)" />
    </xsl:attribute>
    </a>
    Error: System.Xml.Xsl.XslLoadException: Prefix 'addthis' is not defined
    Any Solutions?
  • Chriztian Steinmeier 2800 posts 8791 karma points MVP 8x admin c-trib
    Sep 01, 2011 @ 23:46
    3
    Hi skiltz,
    You need to add a namespace declaration on the <xsl:stylesheet> element to declare the addthis prefix, e.g.:
    <xsl:stylesheet version="1.0" xmlns:addthis="http://www.addthis.com/help/api-spec">
    And you can then do this:
    addthis:url="{umbraco.library:NiceUrl($post/@id)}">...</a>
    /Chriztian
    Sep 01, 2011 @ 23:58
    skiltz
    Thank you heaps.  Appreciated.
