My RSS feed for showing blog posts is working fine except it is still showing the HTML tags such as <p>, <ul> and <li> etc. I don't understand what's going wrong. This is what it looks like in the description tag of the RSS Feed -
<description>
<![CDATA[ <p>Lorem ipsum dolor sit amet, consectetur adipiscing elit. Sed hendrerit consectetur lacus, vitae varius felis auctor eget. Sed fermentum ultrices quam, quis auctor orci vestibulum sed. Proin rutrum porttitor dolor et gravida. Cras pharetra pretium aliquam. Curabitur pharetra tortor ut mauris aliquam vel semper neque dictum. Mauris vitae ultricies est. Cras consequat, lacus non tristique eleifend, velit ante tempor urna, eget pellentesque sem mauris ac nulla. Nullam non lectus ultrices mi consequat laoreet ac quis justo. Etiam a nibh felis, non placerat nibh. Vivamus magna metus, ullamcorper eget euismod at, vestibulum ut arcu. Praesent massa neque, laoreet eget faucibus in, molestie vitae justo. Maecenas quis felis ante, id hendrerit nibh.</p> ]]>
RSS Problem - CDATA still showing HTML tags
Hi there,
<xsl:stylesheet
version="1.0"
xmlns:rssdatehelper="urn:rssdatehelper"
xmlns:dc="http://purl.org/dc/elements/1.1/"
xmlns:content="http://purl.org/rss/1.0/modules/content/"
xmlns:Exslt.ExsltStrings="urn:Exslt.ExsltStrings"
xmlns:BlogLibrary="urn:BlogLibrary"
exclude-result-prefixes="msxml umbraco.library Exslt.ExsltStrings BlogLibrary">
<xsl:variable name="iscommentfeed" select="//macro/iscommentfeed" />
<!-- Update these variables to modify the feed -->
<xsl:variable name="RSSNoItems" select="string('10')"/>
<xsl:variable name="RSSTitle">
<xsl:value-of select="$currentPage/ancestor-or-self::Blog/blogName"/>
<xsl:if test="$iscommentfeed = '1'">
<xsl:text> comment feed</xsl:text>
<xsl:if test="$currentPage [name() = 'BlogPost']">
<xsl:value-of select="concat(' for ', $currentPage/@nodeName)"/>
</xsl:if>
</xsl:if>
<xsl:if test="string-length(umbraco.library:Request('tag')) > 0">
<xsl:value-of select="concat(' for tag ', umbraco.library:Request('tag'))"/>
</xsl:if>
</xsl:variable>
<xsl:variable name="SiteURL" select="concat('http://',string(umbraco.library:RequestServerVariables('HTTP_HOST')))"/>
<xsl:variable name="RSSDescription" select="$currentPage/ancestor-or-self::Blog/blogDescription"/>
<!-- This gets all news and events and orders by updateDate to use for the pubDate in RSS feed -->
<xsl:variable name="pubDate">
<xsl:choose>
<xsl:when test="$iscommentfeed = '1'">
<xsl:for-each select="$currentPage//BlogPostComment">
<xsl:sort select="@createDate" data-type="text" order="descending" />
<xsl:if test="position() = 1">
<xsl:value-of select="@updateDate" />
</xsl:if>
</xsl:for-each>
</xsl:when>
<xsl:otherwise>
<xsl:choose>
<xsl:when test="string-length(umbraco.library:Request('tag')) > 0">
<xsl:for-each select="$currentPage//BlogPost [contains(Exslt.ExsltStrings:lowercase(./tags), Exslt.ExsltStrings:lowercase(umbraco.library:Request('tag')))]">
<xsl:sort select="PostDate" data-type="text" order="descending" />
</xsl:if>
</xsl:for-each>
</xsl:when>
<xsl:otherwise>
<xsl:for-each select="$currentPage//BlogPost">
</xsl:if>
</xsl:for-each>
</xsl:otherwise>
</xsl:choose>
</xsl:otherwise>
</xsl:choose>
</xsl:variable>
<xsl:template match="/">
<!-- change the mimetype for the current page to xml -->
<xsl:value-of select="umbraco.library:ChangeContentType('text/xml')"/>
<xsl:text disable-output-escaping="yes"><?xml version="1.0" encoding="UTF-8"?></xsl:text>
<rss version="2.0"
xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title>
<xsl:value-of select="$RSSTitle"/>
</title>
<link>
<xsl:value-of select="$SiteURL"/>
</link>
<pubDate>
<xsl:value-of select="$pubDate"/>
</pubDate>
<generator>umbraco</generator>
<description>
<xsl:value-of select="$RSSDescription"/>
</description>
<language>en</language>
<xsl:choose>
<xsl:choose>
<xsl:when test="$currentPage [name() = 'BlogPost']">
<xsl:apply-templates select="BlogLibrary:GetCommentsForPost($currentPage/@id)//comment">
<xsl:sort select="@created" order="descending" />
</xsl:apply-templates>
</xsl:when>
<xsl:otherwise>
<xsl:apply-templates select="BlogLibrary:GetCommentsForBlog($currentPage/ancestor-or-self::Blog/@id)//comment">
</xsl:otherwise>
</xsl:choose>
</xsl:when>
<xsl:otherwise>
<xsl:choose>
<xsl:apply-templates select="$currentPage//BlogPost [contains(Exslt.ExsltStrings:lowercase(./tags), Exslt.ExsltStrings:lowercase(umbraco.library:Request('tag')))]">
<xsl:sort select="PostDate" order="descending" />
</xsl:when>
<xsl:otherwise>
<xsl:apply-templates select="$currentPage//BlogPost">
</xsl:otherwise>
</xsl:choose>
</xsl:otherwise>
</xsl:choose>
</channel>
</rss>
</xsl:template>
<xsl:template match="BlogPost">
<xsl:if test="position() <= $RSSNoItems">
<xsl:variable name="link">
<xsl:value-of select="umbraco.library:NiceUrl(@id)"/>
</xsl:variable>
<xsl:variable name="content">
<xsl:value-of select="bodyText"/>
</xsl:variable>
<item>
<title>
</title>
<link>
<xsl:value-of select="$link"/>
</link>
<pubDate>
<xsl:value-of select="umbraco.library:FormatDateTime(PostDate,'r')" />
</pubDate>
<guid>
</guid>
<description>
<xsl:value-of select="concat('<![CDATA[ ',$content,']]>')"/>
</description>
</item>
</xsl:if>
</xsl:template>
</xsl:stylesheet>
Any help would be much appreciated as I really don't know where I'm going wrong.
Daniel
Hi Daniel,
If you want to have the contents of the <description> tags wrapped with CDATA, then you'll need to add the following attribute to the <xsl:output>:
Thenk you can output the 'bodyText' value like so... (I don't see a need to store the value in the $content variable)
<description> <xsl:value-of select="bodyText"/> </description>Cheers, Lee.
Thanks a lot Lee that worked!
I didn't know thats what I needed to add to the <xsl:output> so you've tought me something new today!
Cheers, Daniel
