  • Kasper Dyrvig 246 posts 379 karma points
    Sep 06, 2011 @ 15:26
    Kasper Dyrvig
    Advanced for-each loop
    This is in addition to jQuery tools scrollable - can it be done?
    This is a little more complecated...
    <xsl:param name="currentPage"/>
    <xsl:variable name="productFeedUrl">http://xml.example.com/searchresult.ashx?productgroup=79415</xsl:variable>
    <xsl:variable name="groupsize" select="5" />
    <xsl:template match="/">
      <div id="products">
        <xsl:for-each select="umbraco.library:GetXmlDocumentByUrl($productFeedUrl)//Product">
          <xsl:choose>
            <xsl:when test="ProductInfoUrl != ''">
              <xsl:variable name="productFeed" select="umbraco.library:GetXmlDocumentByUrl(ProductInfoUrl)"/>
              <xsl:choose>
                <xsl:when test="$productFeed != ''">
                  <xsl:apply-templates select="$productFeed/ProductInfoList/*[position() mod $groupsize = 1]" mode="group" />
                </xsl:when>
                <xsl:otherwise>
                  This product could not be found
                </xsl:otherwise>
              </xsl:choose>
            </xsl:when>
            <xsl:otherwise>
              There are no products
            </xsl:otherwise>
          </xsl:choose>
        </xsl:for-each>
    </xsl:template>
    <xsl:template match="ProductInfo" mode="group">
      <div class="row">
        <xsl:apply-templates select=". | following-sibling::ProductInfo[position() &lt; $groupsize]" mode="item" />
    </xsl:template>
    <xsl:template match="ProductInfo" mode="item">
      <div class="item">
        <href="{ProductURL}" class="itemImage"><img src="{AboutProduct/ProductImage/PicBig}" alt="Image"/></a>
        <p><href="{ProductURL}"><xsl:value-of select="AboutProduct/SubHeadLine"/></a></p>
        <href="{ProductURL}" class="itemPrice">Date: <xsl:value-of select="umbraco.library:FormatDateTime(Dates/Date[1], 'd. MMM.')"/><br /><span><xsl:value-of select="PricePrefix"/>&nbsp;<xsl:value-of select="Price"/><xsl:value-of select="umbraco.library:GetDictionaryItem('Price ending')"/></span></a>
        <href="{ProductURL}" class="itemButton">Buy to day</a>
    </xsl:template>
    This works but the productItems are wrapped wrong.
    The output is:
    <div id="products">
    <div class="row">
    <div class="item"> [data] </div>
    <div class="row">
    But I want this:
    <div id="products">
    <div class="row">
    I have puzzled with it for some hours now, but can't calculate the currect solution... help will be appreseated.
    Sep 06, 2011 @ 15:36
    Dirk De Grave
    you'll have to move the <div class="row"></div> out of the ProductInfo template and put it just after the for-each or just before, depending on whether you need to have a row for each product or just a single row div for all products.
      <div id="products"
        <div class="row">
          <div class="row">
          <xsl:choose>
              <xsl:choose>
                </xsl:when>
                <xsl:otherwise>
                </xsl:otherwise>
              </xsl:choose>
            </xsl:when>
            <xsl:otherwise>
            </xsl:otherwise>
          </xsl:choose>
        </xsl:for-each>
    </xsl:template>
    </xsl:template>
      <div class="item">
        <a href="{ProductURL}" class="itemImage"><img src="{AboutProduct/ProductImage/PicBig}" alt="Image"/></a>
        <p><a href="{ProductURL}"><xsl:value-of select="AboutProduct/SubHeadLine"/></a></p>
        <a href="{ProductURL}" class="itemPrice">Date: <xsl:value-of select="umbraco.library:FormatDateTime(Dates/Date[1], 'd. MMM.')"/><br /><span><xsl:value-of select="PricePrefix"/> <xsl:value-of select="Price"/><xsl:value-of select="umbraco.library:GetDictionaryItem('Price ending')"/></span></a>
        <a href="{ProductURL}" class="itemButton">Buy to day</a>
    </xsl:template>
    /Dirk
    Sep 07, 2011 @ 08:08
    Kasper Dyrvig
    Thanks Dirk.
    I need a row for every 5 product. So I guess I need a bit more modification...
    Sep 07, 2011 @ 08:29
    Kasper Dyrvig
    Hey! I solved it! Wohoo! :-)
    The solution is: Gather the productfeeds in one variable and then output the data up to 5 items at a time.
    The code:
    <xsl:variable name="supernodes">
      <Products>
          <xsl:choose>
              <xsl:copy-of select="umbraco.library:GetXmlDocumentByUrl(ProductInfoUrl)/ProductInfoList/ProductInfo"/>
            </xsl:when>
            <xsl:otherwise></xsl:otherwise>
          </xsl:choose>
        </xsl:for-each>
      </Products>
    </xsl:variable>
    <xsl:variable name="superdata" select="make:node-set($supernodes)" />
      <div id="products">
        <xsl:apply-templates select="$superdata/Products/*[position() mod $groupsize = 1]" mode="group" />
    </xsl:template>
      <div class="row">
        <xsl:apply-templates select=". | followng-sibling::ProductInfo[position() &lt; $groupsize]" mode="item" />
    </xsl:template>
      <div class="item">
        <a href="{ProductURL}" class="itemImage"><img src="{AboutProduct/ProductImage/Pic80}" alt="Billede"/></a>
        <a href="{ProductURL}" class="itemPrice">Date: <xsl:value-of select="umbraco.library:FormatDateTime(Dates/Date[1], 'd. MMM.')"/><br /><span><xsl:value-of select="PricePrefix"/>&nbsp;<xsl:value-of select="Price"/><xsl:value-of select="umbraco.library:GetDictionaryItem('Price ending')"/></span></a>
    </xsl:template>
    Now it works perfect!
