What is the best way to join SQL tables in XSLT? I am familiar with joining SQL tables in regular ASP (such as SELECT column_name FROM table_name1 LEFT JOIN table_name2 ON table_name1.column_name=table_name2.column_name), but am having trouble framing it properly in XSLT.
<xsl:variable name = "getAuthor" select="SQL:GetDataSet('DBname', 'SELECT ArticleID, Author, StaffID FROM web_Articles, LEFT JOIN web_Staff ON web_Articles.Author = web_Staff.StaffID, 'getAuthor')"/>
Is there something wrong here that I'm not seeing?
No luck. Here is the fuller code if it helps to see what I am trying to accomplish.
I have two tables that deal with news stories. One (web_Articles) holds the story content (images, text, author id, etc). The other (web_Staff) holds author information. An "Author" column in web_Articles holds the an int value equal to the "AuthorID" in web_Staff. I would rather show "Julie Cole" as author of the story, rather than "2".
When I use the below code, I get the following error:
System.Xml.Xsl.XslLoadException: Expected token ')', found 'getAuthor'. ...es.Author = web_Staff.StaffID, ' -->getAuthor<-- ') An error occurred at C:\inetpub\wwwroot\UT\xslt\634509170863705620_temp.xslt(21,5). at System.Xml.Xsl.XslCompiledTransform.LoadInternal(Object stylesheet, XsltSettings settings, XmlResolver stylesheetResolver) at umbraco.presentation.webservices.codeEditorSave.SaveXslt(String fileName, String oldName, String fileContents, Boolean ignoreDebugging)
<xsl:variable name = "storyID" select = "umbraco.library:RequestQueryString('id')" /> <!-- Grabs the id number from URL -->
<xsl:variable name = "newsStory" select="SQL:GetDataSet('DBname', concat('SELECT ArticleID, ArticleType, ImageFile1, ImageFile2, ImageFile3, ImageFile1Caption, ImageFile2Caption, ImageFile3Caption, Display, ArticleStartDate, Content, Title, Author FROM web_Articles WHERE ArticleID = ', $storyID), 'newsStory')"/> <!-- gets SQL data from external database tables by the id number in the URL -->
<xsl:variable name = "getAuthor" select="SQL:GetDataSet('DBname', 'SELECT Author, FirstName, LastName, StaffID FROM web_Articles LEFT JOIN web_Staff ON web_Articles.Author = web_Staff.StaffID, 'getAuthor')"/> <!-- attempting to grab the Author's first and last name from the Staff table -->
<!--<xsl:variable name = "getAuthor" select="SQL:GetDataSet('DBname', concat('SELECT ArticleID, Author, StaffID FROM web_Articles WHERE ArticleID = ', $storyID), LEFT JOIN web_Staff ON web_Articles.Author = web_Staff.StaffID, 'getAuthor')"/> --> <!-- Here is the same query, but with concat, drawing the ID from the URL -->
<xsl:template match="/">
<xsl:for-each select = "$newsStory//newsStory"> <h1><xsl:value-of select = "Title" disable-output-escaping="yes" /></h1> <span id = "share_newsstory"> <span class = "publish_info"> <xsl:for-each select = "$getAuthor//getAuthor"> <xsl:value-of select = "FirstName" /> <xsl:value-of select = "LastName" /> </xsl:for-each> | <xsl:value-of select="umbraco.library:FormatDateTime(ArticleStartDate, 'MMM d, yyyy')"/></span> <!-- $getAuthor has its own for-each in order to enact the $getAuthor variable. I don't know if this is the right way to do it. --> </span> <xsl:value-of select = "Content" disable-output-escaping="yes" /> </xsl:for-each> </xsl:template>
</xsl:stylesheet>
I'm not sure what to try next. Any guidance would be most appreciated!
Join SQL tables in XSLT
<xsl:variable name = "getAuthor" select="SQL:GetDataSet('DBname', 'SELECT ArticleID, Author, StaffID FROM web_Articles, LEFT JOIN web_Staff ON web_Articles.Author = web_Staff.StaffID, 'getAuthor')"/>Is there something wrong here that I'm not seeing?
Luke
I think there is "," before left join, try remove it.
Hi Luke - you're missing an apostrophe in that call to GetDataSet() - just after web_Staff.StaffID:
<xsl:variable name = "getAuthor" select="SQL:GetDataSet('DBname', 'SELECT Author, FirstName, LastName, StaffID FROM web_Articles LEFT JOIN web_Staff ON web_Articles.Author = web_Staff.StaffID', 'getAuthor')" />Please note that there really is no way to "join SQL tables in XSLT" - you're doing the joining in SQL - just getting the data as XML for use in XSLT.
/Chriztian
Thanks, Chriztian! That set me on the right track. Based off of that string, I got the concat to work as well:
<xsl:variable name = "newsStory" select="SQL:GetDataSet('DBname', concat('SELECT column, names, from, both, tables FROM web_Articles INNER JOIN web_Staff ON web_Articles.Author=web_Staff.StaffID WHERE web_Articles.ArticleID = ', $storyID), 'newsStory')" />is working on a reply...
