  • dwarakesh 50 posts 69 karma points
    Sep 08, 2011 @ 11:13
    dwarakesh
    Multi level navigation XSLT
    my node structure is like
    parent  node-
                   node1
                            - subnode1
                            - subnode2
                   node2
                           - subnode3
                           - subnode4
    i have a  multi level navigation XSlt which produces menu like in the above structure. There is a part of that  XSlt which i dont understand.
     <xsl:if test="$currentPage/descendant::* [@level=1]">
                        <xsl:text>current</xsl:text>
                      </xsl:if>
    what is that @level   value for all the nodes whether it will ne different or same..
    Sep 08, 2011 @ 11:27
    Dirk De Grave
    Hi dwarakesh,
    Each node in your content structure has a level property which is saved to the published xml as an attribute, hence the @level notation. Each top level node (child nodes of 'Content') have level = 1, child nodes of your top level nodes have level = 2 and so on
    in your case, if 'parent node' is a child node of 'Content', it will have a level = 1, node 1 and node 2 will have level = 2, ...
    /Dirk
    Sep 08, 2011 @ 12:01
    dwarakesh
    i m using the below xslt.. in that level 2 menus are not checked.. but i m getting above mentioned structure.. keeps me wondering ..
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
     version="1.0"
     xmlns:umbraco.library="urn:umbraco.library" xmlns:Exslt.ExsltCommon="urn:Exslt.ExsltCommon" xmlns:Exslt.ExsltDatesAndTimes="urn:Exslt.ExsltDatesAndTimes" xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath" xmlns:Exslt.ExsltRegularExpressions="urn:Exslt.ExsltRegularExpressions" xmlns:Exslt.ExsltStrings="urn:Exslt.ExsltStrings" xmlns:Exslt.ExsltSets="urn:Exslt.ExsltSets" xmlns:tagsLib="urn:tagsLib" xmlns:BlogLibrary="urn:BlogLibrary"
     exclude-result-prefixes="msxml umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings Exslt.ExsltSets tagsLib BlogLibrary ">
    <!-- Input the documenttype you want here -->
    <!-- Typically '1' for topnavigtaion and '2' for 2nd level -->
    <!-- Use div elements around this macro combined with css -->
    <!-- for styling the navigation -->
    <xsl:variable name="level" select="1"/>
    <xsl:template match="/">
    <ul id="jsddm">
      <li>
           <xsl:attribute name="class">
             <xsl:if test="$currentPage/@level=$level">
              </xsl:if>
         </xsl:attribute>
     </li>
      <xsl:for-each select="$currentPage/ancestor-or-self::* [@level=$level]/* [@isDoc and string(umbracoNaviHide) != '1']">
      <li>
             <xsl:if test="$currentPage/@id=@id">
              </xsl:if>
         </xsl:attribute>
        <a href="{umbraco.library:NiceUrl(@id)}"><xsl:value-of select="@nodeName"/></a>
        <!-- Drop Down Menu -->
        <xsl:if test="count(./* [@isDoc and string(umbracoNaviHide) != '1']) &gt; 0">
           <ul>
             <xsl:for-each select="./* [@isDoc and string(umbracoNaviHide) != '1']">
                 <li>
                      </xsl:if>
                    </xsl:attribute>
                   <a href="{umbraco.library:NiceUrl(@id)}"><xsl:value-of select="@nodeName"/></a></li>
             </xsl:for-each>
           </ul>
        </xsl:if>
      <!-- End of Drop Down Menu -->
      </li>
      </xsl:for-each>
      </ul>
    </xsl:template>
    </xsl:stylesheet>
