I have horixzontal menu & its child elements like this ....
element1
>c1element1
>>c1c1element1
>>c1c2element1
>c2element1
>>c2c1element1
>>c2c2element1
element2
element3
Lets say i apply role based protection to element named "c1element1"
then my horizontal menu becomes something like this....
>>c2element1
>>>c2c1element1
>>>c2c2element1
>element2
>element3
my xslt which generates horizontal menu is ....
<?xml version="1.0" encoding="UTF-8"?><!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> ]><xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:msxml="urn:schemas-microsoft-com:xslt" xmlns:umbraco.library="urn:umbraco.library" xmlns:Exslt.ExsltCommon="urn:Exslt.ExsltCommon" xmlns:Exslt.ExsltDatesAndTimes="urn:Exslt.ExsltDatesAndTimes" xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath" xmlns:Exslt.ExsltRegularExpressions="urn:Exslt.ExsltRegularExpressions" xmlns:Exslt.ExsltStrings="urn:Exslt.ExsltStrings" xmlns:Exslt.ExsltSets="urn:Exslt.ExsltSets" xmlns:tagsLib="urn:tagsLib" xmlns:BlogLibrary="urn:BlogLibrary" exclude-result-prefixes="msxml umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings Exslt.ExsltSets tagsLib BlogLibrary "><xsl:output method="xml" omit-xml-declaration="yes"/><xsl:param name="currentPage"/><!-- update this variable on how deep your site map should be --><xsl:variable name="maxLevelForSitemap" select="4"/><xsl:template match="/"><xsl:call-template name="drawNodes"> <xsl:with-param name="parent" select="$currentPage/ancestor-or-self::* [@isDoc and @level=1]"/> </xsl:call-template></xsl:template><xsl:template name="drawNodes"> <xsl:param name="parent"/> <!--xsl:copy-of select="$parent"/--> <xsl:if test="umbraco.library:IsProtected($parent/@id, $parent/@path) = 0 or (umbraco.library:IsProtected($parent/@id, $parent/@path) = 1 and umbraco.library:IsLoggedOn() = 1)"> <div id="myslidemenu" class="jqueryslidemenu"> <ul> <xsl:for-each select="$parent/*[string(./data [@alias='umbracoNaviHide']) != '1' and @level <= $maxLevelForSitemap]"> <xsl:if test="name(.) != 'otherTemplates'"> <li> <xsl:if test="@id = $currentPage/@id"> <a href="{umbraco.library:NiceUrl(@id)}" class="current"><xsl:value-of select="@nodeName"/></a> </xsl:if> <xsl:if test="@id != $currentPage/@id"> <a href="{umbraco.library:NiceUrl(@id)}"><xsl:value-of select="@nodeName"/></a> </xsl:if> <xsl:if test="count(./*[string(./data [@alias='umbracoNaviHide']) != '1' and @level <= $maxLevelForSitemap]) > 0"> <xsl:call-template name="drawNodes2"> <xsl:with-param name="parent" select="."/> </xsl:call-template> </xsl:if> </li> </xsl:if> </xsl:for-each> </ul> </div> </xsl:if> </xsl:template> <xsl:template name="drawNodes2"> <xsl:param name="parent"/> <xsl:if test="umbraco.library:IsProtected($parent/@id, $parent/@path) = 0 or (umbraco.library:IsProtected($parent/@id, $parent/@path) = 1 and umbraco.library:IsLoggedOn() = 1)"> <ul> <xsl:for-each select="$parent/*[string(./data [@alias='umbracoNaviHide']) != '1' and @level <= $maxLevelForSitemap]"> <li> <xsl:if test="count(./*[string(./data [@alias='umbracoNaviHide']) != '1' and @level <= $maxLevelForSitemap]) < 1"> <a href="{umbraco.library:NiceUrl(@id)}"><xsl:value-of select="@nodeName"/></a> </xsl:if> <xsl:if test="count(./*[string(./data [@alias='umbracoNaviHide']) != '1' and @level <= $maxLevelForSitemap]) > 0"> <xsl:if test="name(.)= 'PublicationsPage'"> <a href="{umbraco.library:NiceUrl(@id)}"> <xsl:value-of select="@nodeName"/> </a> </xsl:if> <xsl:if test="name(.) != 'PublicationsPage'"> <a href="{umbraco.library:NiceUrl(@id)}"> <xsl:value-of select="@nodeName"/> >> </a> <ul> <xsl:call-template name="drawNodes3"> <xsl:with-param name="parent" select="."/> </xsl:call-template> </ul> </xsl:if> </xsl:if> </li> </xsl:for-each> </ul> </xsl:if> </xsl:template> <xsl:template name="drawNodes3"> <xsl:param name="parent"/> <xsl:if test="umbraco.library:IsProtected($parent/@id, $parent/@path) = 0 or (umbraco.library:IsProtected($parent/@id, $parent/@path) = 1 and umbraco.library:IsLoggedOn() = 1)"> <xsl:for-each select="$parent/*[string(./data [@alias='umbracoNaviHide']) != '1' and @level <= $maxLevelForSitemap]"> <li><a href="{umbraco.library:NiceUrl(@id)}"><xsl:value-of select="@nodeName"/></a> <xsl:if test="count(./*[string(./data [@alias='umbracoNaviHide']) != '1' and @level <= $maxLevelForSitemap]) > 0"> <xsl:call-template name="drawNodes2"> <xsl:with-param name="parent" select="."/> </xsl:call-template> </xsl:if> </li> </xsl:for-each> </xsl:if> </xsl:template> </xsl:stylesheet>
how to achive proper horizontal menu even after applying public access protection
You could try using the umbraco Library HasAccess around your loop.
<xsl:if test="umbraco.library:HasAccess(@id,@path)"> <xsl:for-eachselect="$parent/*[string(./data [@alias='umbracoNaviHide']) != '1' and @level <= $maxLevelForSitemap]"> <li><ahref="{umbraco.library:NiceUrl(@id)}"><xsl:value-ofselect="@nodeName"/></a> <xsl:iftest="count(./*[string(./data [@alias='umbracoNaviHide']) != '1' and @level <= $maxLevelForSitemap]) > 0"> <xsl:call-templatename="drawNodes2"> <xsl:with-paramname="parent"select="."/> </xsl:call-template> </xsl:if> </li> </xsl:for-each></xsl:if>
problem in horizontal menu while applying public access protection
element1
>c1element1
>>c1c1element1
>>c1c2element1
>c2element1
>>c2c1element1
>>c2c2element1
element2
element3
element1
>c1element1
>>c2element1
>>>c2c1element1
>>>c2c2element1
>element2
>element3
