  • Matthew Jarvis 129 posts 129 karma points
    Sep 20, 2011 @ 16:33
    Matthew Jarvis
    Menu help
    Hey,
    Currently getting perplexed by a nested menu i would like to achieve shown below:-
    Basically initial menu items that i want to be displayed are Home>The College>Courses>Student Life
    Upon clicking any of these top level nodes, sub nodes are then displayed underneath. Sub level nodes will also appear if the page on view belongs in the same level. e.g viewing the page 'jobs' will result in all of the top level nodes on display together with 'About The College', 'Success at The College', 'Facilities' etc
    At the moment, the above has been achieved through using the Sitemap XSLT
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
    version="1.0"
    xmlns:umbraco.library="urn:umbraco.library" xmlns:Exslt.ExsltCommon="urn:Exslt.ExsltCommon" xmlns:Exslt.ExsltDatesAndTimes="urn:Exslt.ExsltDatesAndTimes"
    xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath" xmlns:Exslt.ExsltRegularExpressions="urn:Exslt.ExsltRegularExpressions"
    xmlns:Exslt.ExsltStrings="urn:Exslt.ExsltStrings" xmlns:Exslt.ExsltSets="urn:Exslt.ExsltSets"
    exclude-result-prefixes="msxml umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings
    Exslt.ExsltSets ">
    <!-- update this variable on how deep your site map should be -->
    <xsl:variable name="maxLevelForSitemap" select="4"/>
    <xsl:template match="/">
    <div id="sitemap">
    <xsl:call-template name="drawNodes">
    <xsl:with-param name="parent" select="$currentPage/ancestor-or-self::* [@isDoc and @level=1]"/>
    </xsl:call-template>
    </xsl:template>
    <xsl:template name="drawNodes">
    <xsl:param name="parent"/>
    <xsl:if test="umbraco.library:IsProtected($parent/@id, $parent/@path) = 0 or (umbraco.library:IsProtected($parent/@id, $parent/@path) = 1 and
    umbraco.library:IsLoggedOn() = 1)">
    <ul><xsl:for-each select="$parent/* [@isDoc and string(umbracoNaviHide) != '1' and @level &lt;= $maxLevelForSitemap]">
    <li>
    <xsl:value-of select="@nodeName"/></a>
    <xsl:if test="count(./* [@isDoc and string(umbracoNaviHide) != '1' and @level &lt;= $maxLevelForSitemap]) &gt; 0">
    <xsl:with-param name="parent" select="."/>
    </xsl:if>
    </li>
    </xsl:for-each>
    </ul>
    </xsl:if>
    </xsl:template>
    </xsl:stylesheet>
    Any guidance would be much appreciated.
    Many Thanks
    Matt
    Sep 21, 2011 @ 11:03
