See the slider on the right? It shows 8 slides. The last to slides are black, but they do have an image and the image does show; if i disable all scripting and css it shows a list of all images. They are there.
The strange thing now is that if I remove 2 slides (slides come from nodes, so any node in the list) all remaining 6 slides are shown. What is the deal here.....?
haha yeah I fixed it a few minutes ago, someone on twitter came with the solution; the width setting for the div.strip was not wide enough, so the last to slides where wrapped in a very small area.... I knew it was something simple, but was more looking for a script setting saying max-slides=6 or something.
slider problem
It's not a real xslt problem I think, the slider is generated with xslt but I think the problem is somewhere else.
Have a look at http://www.lievevrouw.nl/
*freaked out...
Hey Roland,
I see 7 images and 7 slides, no problem here (PC & Chrome).
Sure you didn't have a caching problem?
Rich
so, problem solved. thanx for looking though :)
