Currently don't see an issue, except for the 2nd $currentPage, which you should replace with ./data [@alias = $itemContent], (if $itemContent has been defined before of course, can't find it in above snippet)
I have updated the 2nd $CurrentPage as suggested. Do I need to define $itemContent as a variable?
The error I'm getting is this...
System.Xml.Xsl.XslLoadException:
XSLT compile error. An error occurred at (40,89). --->
System.Xml.XmlException: '<', hexadecimal value 0x3C, is an invalid
attribute character. Line 40, position 89.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.Throw(String res, String[] args)
at System.Xml.XmlTextReaderImpl.Throw(Int32 pos, String res, String[]
args)
at System.Xml.XmlTextReaderImpl.ParseAttributeValueSlow(Int32 curPos,
Char quoteChar, NodeData attr)
at System.Xml.XmlTextReaderImpl.ParseAttributes()
at System.Xml.XmlTextReaderImpl.ParseElement()
at System.Xml.XmlTextReaderImpl.ParseElementContent()
at System.Xml.XmlTextReaderImpl.Read()
at System.Xml.XmlTextReader.Read()
at System.Xml.Xsl.Xslt.XsltInput.ReadNextSiblingHelper()
at System.Xml.Xsl.Xslt.XsltInput.ReadNextSibling()
at System.Xml.Xsl.Xslt.XsltInput.MoveToFirstChildAny()
at System.Xml.Xsl.Xslt.XsltInput.MoveToFirstChild()
at System.Xml.Xsl.Xslt.XsltLoader.LoadInstructions(List`1 content,
InstructionFlags flags)
at System.Xml.Xsl.Xslt.XsltLoader.LoadLiteralResultElement(Boolean
asStylesheet)
asStylesheet)
at System.Xml.Xsl.Xslt.XsltLoader.XslForEach()
asStylesheet)
at System.Xml.Xsl.Xslt.XsltLoader.LoadTemplate(NsDecl
stylesheetNsList)
at System.Xml.Xsl.Xslt.XsltLoader.LoadRealStylesheet()
at System.Xml.Xsl.Xslt.XsltLoader.LoadDocument()
at System.Xml.Xsl.Xslt.XsltLoader.LoadStylesheet(XmlReader reader,
Boolean include)
--- End of inner exception stack trace ---
Boolean include)
at System.Xml.Xsl.Xslt.XsltLoader.Load(Compiler compiler, Object
stylesheet, XmlResolver xmlResolver)
at System.Xml.Xsl.Xslt.Compiler.Compile(Object stylesheet,
XmlResolver xmlResolver, QilExpression& qil)
at System.Xml.Xsl.XslCompiledTransform.CompileXsltToQil(Object
stylesheet, XsltSettings settings, XmlResolver stylesheetResolver)
at System.Xml.Xsl.XslCompiledTransform.LoadInternal(Object
at System.Xml.Xsl.XslCompiledTransform.Load(XmlReader stylesheet,
at umbraco.macro.CreateXsltTransform(XmlTextReader xslReader, Boolean
debugMode)
at
umbraco.presentation.umbraco.developer.Xslt.xsltVisualize.visualizeDo_Click(Object
sender, EventArgs e)
Answer to 1st question: Depends, if you *know* the propertyAlias and it will be static, use that one, otherwise if $itemContent is to be dynamic, use a variable.
I've added the double quote and it's cleared the error but now I'm getting 'The variable or parameter 'itemContent' is either not defined or it is out of scope'
I assume this is because I haven't defined $itemContent?
I have 2 aliases that I need to display - itemContent and itemContentImage - each are populated in the child pages that will form the accordian.
Sorry, I'm a bit confused as to what I need to define and where!
Problems Updating XSLT from New Schema to Old Schema
I'm using XSLT and JQuery to create an accordian menu using child pages of a node.
The code has previously worked in Umbraco 4.5.2 but I am now trying to get it to work in 4.0.3 but not having much luck!
I have updated the code for the old schema but I think there may be something wrong with my value-of select as it is throwing an error!
Here is my xslt...
Any help appreciated!
Rachel
Rachel,
And more specifically, what error do you get?
Looking forward to your info.
/Dirk
Hi Dirk,
Rachel
Just seen that you've not closed the
<xsl:value-ofselect="$currentPage/data [@alias=$itemContent] />
the select attribute, maybe that's the issue. Can you try adding a closing double quote for the select attribute?
/Dirk
Rachel
yes, indeed, if you haven't defined that one, you need to, unless you can set it static, (which i assume here), so above snippet would be
<xsl:value-of select="./data [@alias='itemContent'] />
/Dirk
Thank you! I now don't get any errors but the xslt isn't generating any output :(
When I use the visualize xslt I get nothing and encode/ decode result just returns <ul id="accordion"></ul>
I've also tried defining a specific node but still no result returned.
Rachel
