  • Umbraco 137 posts 294 karma points
    Oct 19, 2011 @ 16:22
    Umbraco
    Need help with XSLT for the first child node of the current node
    I am configuring a Contour form and after the user has submitted the form I want to redirect them to the first child node of the page on which the form is placed.
    But my XSLT is very rusty, I have last used it 7 years ago and never with Umbraco. Can someone point me in the right direction?
    Thank you!
  • Chriztian Steinmeier 2800 posts 8790 karma points MVP 8x admin c-trib
    Oct 20, 2011 @ 00:37
    Hi Michiel,
    Doesn't Contour have a behavior like that? I seem to recall a "Send to page" property on the "Settings" tab of a Form...
    Otherwise, do you want to perform a browser redirect or just render the contents of the child page?
    /Chriztian
    Oct 20, 2011 @ 10:34
    Umbraco
    Yeah, it has a redirect to page option, you can pick a node or enter XSLT. Because I need to reuse the form across multiple sites, I want the behavior to be: redirect to first child node. And I need to use the XSLT option for that.
     And I'd prefer a redirect, because that's easiest to measure as a goal conversion in Google Analytics.
  • Dan Okkels Brendstrup 101 posts 197 karma points
    Nov 16, 2011 @ 16:00
    Hi Michiel,
    I'm not sure what the implied context is when you enter an XPath expression for Contour, but presuming it recognizes the standard $currentPage variable, then this should work:
    $currentPage/*[@isDoc][1]
    ...which basically just points to the first child document node under the current page. Instead of the "*" you can of course specify any doctype, in which case the [@isDoc] test becomes superfluous, e.g.:
    $currentPage/Page[1]
    Will that work?
    Nov 17, 2011 @ 10:33
    Umbraco
    Hi Dan,
    Thanks for your suggestion. Unfortunately, anything I enter into the XPath field results in an exception ("input string was not in a correct format") on the website when submitting the form. I have submitted that to support, when it is resolved I will try your XPath.
    Thanks!
    Nov 17, 2011 @ 10:44
    Hmm, I can't find any documentation on the redirect-to-XPath functionality, but perhaps the $currentPage variable is unnecessary. How about simply this:
    ./*[@isDoc][1]
    Will that work?
    Nov 17, 2011 @ 11:44
    Umbraco
    Not a single XPath query I have tried (and i tried lots) works, they all result in the same exception when submitting the form.
