  • MrBilde 13 posts 33 karma points
    Oct 21, 2011 @ 13:54
    MrBilde
    Double entries using Cultiv Search Engine Sitemap
    Just installed the package "CultivSearchEngineSitemap 2.0.1" on my Umbraco 4.7.1.
    But it seems to generate double entries like this:
    <urlset xsi:schemaLocation="http://www.sitemaps.org/schemas/sitemap/0.9 http://www.sitemaps.org/schemas/sitemap/0.9/sitemap.xsd">
    <url>
    <loc>http://domain.comhttp://domain.com/site.aspx</loc>;
    <lastmod>2011-10-18T14:55:54+00:00</lastmod>
    </url>
    I found out that if i commented out urlPrefix it would remove the first "http://domain.com" entry:
    (seems like NiceUrl returns the full path with prefix?)
    <loc>
    <!--xsl:value-of select="$urlPrefix" /-->
    <xsl:value-of select="umbraco.library:NiceUrl(@id)" />
    </loc>
    But the schemaLocation still have double entry. Any ideas why this is happening?
    Here is my sitemap.xslt:
    <!DOCTYPE xsl:stylesheet [
      <!ENTITY nbsp "&#x00A0;">
    <xsl:stylesheet
      version="1.0"
      xmlns:umbraco.library="urn:umbraco.library" xmlns:Exslt.ExsltCommon="urn:Exslt.ExsltCommon" xmlns:Exslt.ExsltDatesAndTimes="urn:Exslt.ExsltDatesAndTimes" xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath" xmlns:Exslt.ExsltRegularExpressions="urn:Exslt.ExsltRegularExpressions" xmlns:Exslt.ExsltStrings="urn:Exslt.ExsltStrings" xmlns:Exslt.ExsltSets="urn:Exslt.ExsltSets" xmlns:umbraco.contour="urn:umbraco.contour"
      exclude-result-prefixes="msxml umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings Exslt.ExsltSets umbraco.contour ">
      <xsl:variable name="urlPrefix">
        <xsl:text>http://</xsl:text>
        <xsl:value-of select="umbraco.library:RequestServerVariables('HTTP_HOST')" />
      </xsl:variable>
      <!-- update this variable on how deep your site map should be -->
      <xsl:variable name="maxLevelForSitemap" select="100"/>
      <xsl:template match="/">
        <!-- change the mimetype for the current page to xml -->
        <xsl:value-of select="umbraco.library:ChangeContentType('text/xml')"/>
        <xsl:call-template name="drawNodes">
          <xsl:with-param name="parent" select="$currentPage/ancestor-or-self::*[@level=1]"/>
        </xsl:call-template>
      </xsl:template>
      <xsl:template name="drawNodes">
        <xsl:param name="parent"/>
        <xsl:if test="umbraco.library:IsProtected($parent/@id, $parent/@path) = 0
                or (umbraco.library:IsProtected($parent/@id, $parent/@path) = 1 and umbraco.library:IsLoggedOn() = 1)
                and @level &lt;= $maxLevelForSitemap ">
          <xsl:for-each select="$parent/* [@isDoc and string(umbracoNaviHide) != '1'] | $parent/node [string(./data [@alias='umbracoNaviHide']) != '1']">
            <!-- If the document does not have a template, nothing is shown in the frontend anyway.
            So this is not proper content and should not be in the sitemap -->
            <xsl:if test="@template &gt; 0">
              <url>
                <loc>
                </loc>
                <lastmod>
                  <xsl:value-of select="umbraco.library:FormatDateTime(@updateDate, 'yyyy-MM-ddTHH:mm:ss+00:00')" />
                </lastmod>
                <xsl:if test="./data [@alias='searchEngineSitemapChangeFreq'] != '' or searchEngineSitemapChangeFreq != ''">
                  <changefreq>
                    <xsl:value-of select="./data [@alias='searchEngineSitemapChangeFreq'] | searchEngineSitemapChangeFreq" />
                  </changefreq>
                </xsl:if>
                <xsl:if test="./data [@alias='searchEngineSitemapPriority'] != '' or searchEngineSitemapPriority != ''">
                  <priority>
                    <xsl:value-of select="./data [@alias='searchEngineSitemapPriority'] | searchEngineSitemapPriority" />
                  </priority>
                </xsl:if>
              </url>
            </xsl:if>
            <xsl:if test="(count(./* [@isDoc and string(umbracoNaviHide) != '1' and @level &lt;= $maxLevelForSitemap]) &gt; 0) or (count(./node [string(./data [@alias='umbracoNaviHide']) != '1' and @level &lt;= $maxLevelForSitemap]) &gt; 0)">
                <xsl:with-param name="parent" select="."/>
            </xsl:if>
          </xsl:for-each>
        </xsl:if>
      </xsl:template>
    </xsl:stylesheet>
    Oct 21, 2011 @ 14:02
    MrBilde
    Ops, just noticed that the schemaLocationis indeed isn't a double entry :-)
    But it seems like the urlPrefix might be a bug?
  • Chriztian Steinmeier 2800 posts 8790 karma points MVP 8x admin c-trib
    Oct 21, 2011 @ 23:52
    Hi MrBilde,
    The reason for the urlPrefix in the macro (I think) is because NiceUrl() normally doesn't output the full URL - but there's a web.config setting for controlling that, so you might find that in your case it's set to output complete URLs?
    /Chriztian
    - Yep, the schemaLocation attribute actually needs to be like that :-)
    Oct 24, 2011 @ 09:04
    MrBilde
    Hm.. can't recall that I've changed anything in the web.config like that, but it sounds very plausible. Thanks for the help!
