  • Rajeev 126 posts 154 karma points
    Oct 21, 2011 @ 14:28
    Rajeev
    Issue for converting XSLT Schema from 4.0 to 4.5
    I am trying to convert 4.0 XSLT to 4.5 without success for the following lines.
    Could any one help me in doing this?
    1) <xsl:for-each select="$currentPage/ancestor-or-self::node/node [@level = 2 and string(data[@alias='umbracoNaviHide']) != '1']">
    2) <xsl:if test="$currentPage/ancestor-or-self::node/@id = current()/@id">
    The translator converts this to
    1) <xsl:for-each select="$currentPage/ancestor-or-self::node/* [@isDoc][@level = 2 and string(umbracoNaviHide) != '1']">
    But this is not outputing anything. Not getting exactly the corresponding for $currentPage/ancestor-or-self::node/node?
    Can any one help on this?
    Thanks in advance,
    Rajeev
    Oct 21, 2011 @ 14:38
    Tom Fulton
    Hi Rajeev,
    It looks like the converter missed changing ::node to ::* [@isDoc].  They should be:
    1) <xsl:for-each select="$currentPage/ancestor-or-self::* [@isDoc]/* [@isDoc][@level = 2 and string(umbracoNaviHide) != '1']">
    2) <xsl:if test="$currentPage/ancestor-or-self::* [@isDoc]/@id = current()/@id">
    This is because the old schema stored each node as <node id="..">, and the new schema stores each node using its doctype alias, <NewsPage id=".." isDoc>
    See the wiki for more info and some examples.
    Tom
    Oct 21, 2011 @ 14:50
    Rajeev
    Thank you Tom. it worked. Appreciate your quick reply.
    -Rajeev
