  • Dmitry 6 posts 26 karma points
    Nov 01, 2011 @ 10:31
    Dmitry
    Problem with DeleteLineItem
    I use following xslt to remove single item from cart:
    <xsl:variable name="result" select="CommerceLibrary:DeleteLineItem(number($deleteCartItemIndex))"></xsl:variable>
    <xsl:variable name="pipelineResult" select="CommerceLibrary:ExecuteBasketPipeline()"></xsl:variable>
    First call fails with exception:
    deleted object would be re-saved by cascade (remove deleted object from associations)[UCommerce.EntitiesV2.OrderLine#185]"}
    Can somebody suggest what could be the reason?
    Nov 02, 2011 @ 06:17
    Dmitry
    But for the same basket ClearBasket method works perfectly
  • Dan Okkels Brendstrup 101 posts 197 karma points
    Nov 11, 2011 @ 00:31
    I'm afraid I can't help you, but I think you'll have better luck with this topic in the uCommerce support forum:
    http://our.umbraco.org/projects/website-utilities/ucommerce/ucommerce-support
