  • Martin 278 posts 662 karma points
    Nov 02, 2011 @ 14:13
    Martin
    Position Problem Inside Macro / Macro Container
    Hi, Im having some issues with applying a css class based on position within a macro.
    I am also using this macro with a macro container.
    My html output is only applying the first position class.
    Any help would be grateful
    Martin
    <xsl:output method="xml" omit-xml-declaration="yes" indent="yes"/>
        <xsl:param name="currentPage"/>
        <xsl:variable name="title" select="/macro/title"/>
        <xsl:variable name="info" select="/macro/info"/>
        <xsl:variable name="image" select="/macro/image/Image"/>
        <xsl:variable name="link" select="/macro/link"/>
        <xsl:template match="/">
      <!-- start writing XSLT -->
        <xsl:if test="$title and $info and $image">
        <div>
    <!-- Apply class on position -->
                    <xsl:if test="position() = 1">
                            <xsl:attribute name="class">alpha</xsl:attribute>
                    </xsl:if>
                    <xsl:if test="position()  = 2">
                            <xsl:attribute name="class">omega</xsl:attribute>
                    </xsl:if>
    <!--  link around all -->
          <xsl:if test="$link">
          <href="{umbraco.library:NiceUrl($link)}">
    <!-- title and info -->
            <div class="four columns alpha">
              <h5><xsl:value-of select="$title"/></h5>
              <p><xsl:value-of select="$info"/></p>
    <!-- thumbnail image -->
            <div class="two columns omega">
            <xsl:if test="$image">
              <img src="{$image/umbracoFile}" width="100%" />
            </xsl:if>
          </a>
          </xsl:if>
        </xsl:if>
        </xsl:template>
    Nov 02, 2011 @ 14:23
    Martin
    Ive also tried this approach, but it still output only the "alpha" class
     <xsl:choose>
                <xsl:when test="position() = 1">
                </xsl:when>
                <xsl:when test="position() = last()">
                </xsl:when>
            </xsl:choose>
  • Jacob Jensen 40 posts 60 karma points
    Nov 02, 2011 @ 14:25
    Jacob Jensen
    Ur template match="/" is the root node, and there is only a node at position() = 1
    with jquery
    $(".alpha:last").removeClass('alpha').addClass('omega');
    /J
    Nov 02, 2011 @ 14:37
    Martin
    Thanks Jacob,
    Im new to xslt & relunctant to use jquery.
    Nov 02, 2011 @ 14:39
    Jacob Jensen
    yes, but ur macro only shows one item at the time, so its kinda hard to know when its the last without a parameter more.
    /J
  • Andrei Canef 33 posts 84 karma points
    Nov 05, 2011 @ 21:38
    Andrei Canef
    Hi Martin,
    Could you please give me a bit of details as to what you're trying to achieve? I am a bit confused because, in a macro, you'll only ever have 1 element (the image you're pointing to). As such, the only test case being hit is the one where your position = 1.
