Hi, i have a problem with my googlemaps. I have a website where i use the multinodetree picker to select places. And each place has its own lattitude and longtitude. I use a for-each to get all my locations and print them on my googlemap. Now this isnt the problem it al works like a charm. But the problem lies in ie7 and ie8. In these browser i dont see the zoom and move controls of googlemaps. (i use jquery.googlemaps.1.01.js) to render the googlemap.
I have no javascript errors in my console when i am using firefox or chrome. But when i look into ie7 the console gives me an error that there is a "Unable to get value of the property 'icon': object is null or undefined" in the googlemaps javascript file.
Now my knowledge of javascript isnt very well. So i think that the problem lies in the last item my for-each prints since there is also a comma after the last location and i believe this might cause my problem. So is it possible with xslt to change the last item my for-each prints ?
Dont know if this is the right place to post it, so thanks in advance.
Problem with xslt and googlemaps
Greetings Martijn
well, show us your code so we can have a look at it and help you resolve it...
/Dirk
