I hope this helps, this is a 2nd level menu that I am using.
<!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> ]>
<xsl:stylesheet
version="1.0"
<xsl:variable name="AllLevel" select="1"/>
<!-- Input the documenttype you want here -->
<!-- Typically '1' for topnavigtaion and '2' for 2nd level -->
<!-- Use div elements around this macro combined with css -->
<!-- for styling the navigation -->
<xsl:variable name="level" select="2"/>
<xsl:template match="/">
<ul>
<xsl:for-each select="$currentPage/ancestor-or-self::* [@isDoc and @level=$level]/* [@isDoc and string(umbracoNaviHide) != '1']">
<li>
<xsl:if test="$currentPage/ancestor-or-self::*/@id = current()/@id">
<!-- we're under the item - you can do your own styling here -->
<xsl:attribute name="class">Selected</xsl:attribute>
</xsl:if>
</a>
</li>
</xsl:for-each>
</ul>
</xsl:template>
</xsl:stylesheet>
Static second level navigation
Hi!
I trying to make a static level 2 navigation, but it is not working.
My goal is to make a second level navigation what will be visible from all pages, what contains in a parent.
This one not working.
<ul class="pages">
<xsl:for-each select="$currentPage/ancestor-or-self::*[@isDoc and @level = 2]/* [@isDoc and string(umbracoNaviHide) != '1']">
<li>
<xsl:if test="@id = $currentPage/@id">
<xsl:attribute name="class">f</xsl:attribute>
</xsl:if>
<a class="navigation" href="{umbraco.library:NiceUrl(@id)}">
<span><xsl:value-of select="@nodeName"/></span>
</a>
</li>
</xsl:for-each>
</ul>
Please help!
Hi Alexadar,
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> ]> <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:msxml="urn:schemas-microsoft-com:xslt" xmlns:umbraco.library="urn:umbraco.library" xmlns:Exslt.ExsltCommon="urn:Exslt.ExsltCommon" xmlns:Exslt.ExsltDatesAndTimes="urn:Exslt.ExsltDatesAndTimes" xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath" xmlns:Exslt.ExsltRegularExpressions="urn:Exslt.ExsltRegularExpressions" xmlns:Exslt.ExsltStrings="urn:Exslt.ExsltStrings" xmlns:Exslt.ExsltSets="urn:Exslt.ExsltSets" exclude-result-prefixes="msxml umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings Exslt.ExsltSets "> <xsl:output method="xml" omit-xml-declaration="yes" /> <xsl:param name="currentPage"/> <xsl:variable name="AllLevel" select="1"/> <!-- Input the documenttype you want here --> <!-- Typically '1' for topnavigtaion and '2' for 2nd level --> <!-- Use div elements around this macro combined with css --> <!-- for styling the navigation --> <xsl:variable name="level" select="2"/> <xsl:template match="/"> <ul> <xsl:for-each select="$currentPage/ancestor-or-self::* [@isDoc and @level=$level]/* [@isDoc and string(umbracoNaviHide) != '1']"> <li> <a href="{umbraco.library:NiceUrl(@id)}"> <xsl:if test="$currentPage/ancestor-or-self::*/@id = current()/@id"> <!-- we're under the item - you can do your own styling here --> <xsl:attribute name="class">Selected</xsl:attribute> </xsl:if> <xsl:value-of select="@nodeName"/> </a> </li> </xsl:for-each> </ul> </xsl:template> </xsl:stylesheet>Good luck :)
Dmitrij
