  • Fredrik Esseen 610 posts 906 karma points
    Dec 07, 2011 @ 09:45
    Fredrik Esseen
    Problems with RenderMacroContent
    Hi!
    Im trying to put the Cog navigation in a another macro and render it but it wont work.
    im using 4.7.1
    Are there a syntax error somewhere?
    <xsl:variable name="rootNode" select="$currentPage/ancestor-or-self::*[@isDoc] [@level=2]/@id" />
      <xsl:variable name="macro">
    <![CDATA[<?UMBRACO_MACRO macroAlias="SubNavigation" startingLevel="2" recurse="1" selectBranches="3" maxMenuDepth="6" ulBaseClass="vertical" branchClass="branch" selectedClass="selected" expandChildren="1" forceHome="0" securityTrimming="1" runat="server" forceNode="]]><xsl:value-of select="$rootNode"/>
    <![CDATA["></?UMBRACO_MACRO>]]>
    </xsl:variable>
      <xsl:value-of select="umbraco.library:RenderMacroContent($macro, $currentPage/@id)" disable-output-escaping="yes"/>
  • Lee Kelleher 4026 posts 15836 karma points MVP 13x admin c-trib
    Jan 25, 2012 @ 17:07
    Lee Kelleher
    Hi froad,
    Not sure if you found a solution for this already?
    Does the XSLT throw a syntax error? (as the syntax looks fine to me).  Have you tried it with hard-coding the "forceNode" parameter?
    Wondering if there is a better way to do this, rather than using RenderMacroContent? As in trying to pass in the right nodeId into the CogNav directly?
    Cheers, Lee
    Jan 26, 2012 @ 07:58
    Fredrik Esseen
    Hi Lee!
    No I didnt find a solution to this but I did just as you suggested, I cahnged the way to approach the problem :)
