  • Charles 2 posts 22 karma points
    Dec 12, 2011 @ 14:22
    Charles
    Load content based on page picker (Using Ultimate Picker)
    I have a series of boxes that contain information, that I want to be able to display on multiple pages.
    1. I have created a data type that uses the ultimate picker to choose pages based on ID. This works.
    2. Have referenced this in the Standard Document Type (
    chooseInfoBoxes is the Alias) and can select the items I want to show from the repository. All good so far.
    3. I need it to loop through the items in the repository, and if the info box has been ticked on the chooseInfoBoxes checkbox list. I thought i would simply need to test if the checkbox had been ticked, but I think i'm missing something. I'm fairly new to XSLT so any help pointing me in the right direction would be fantastic!
        <div id="infoBoxWrapper">
          <ul class="infoBox">
           <xsl:if test="chooseInfoBoxes='1' ">
            <xsl:for-each select="umbraco.library:GetXmlNodeById(1933)/homeInfoBoxItem [@isDoc]">
           <li class="infoBoxInner">
                <h1><xsl:value-of select="@nodeName"/></h1>
                <p><xsl:value-of select="infoBoxDescription"/></p>
            <xsl:if test="infoBoxLink != ''">
              <a href="{umbraco.library:NiceUrl(infoBoxLink)}">read more</a>
            </xsl:if>
            <img class="floatRight margin10" src="{infoBoxImage}" alt="{@nodeName}" width="150" height="150" align="right" />
          </li>
           </xsl:for-each>
            </xsl:if>
        </ul>
    Dec 12, 2011 @ 18:11
    Charles
    I've managed to tweak something I found here:
    http://blog.leekelleher.com/2009/09/08/umbraco-ultimate-picker-xslt-example/
    This is my finished XSLT, hope it helps anyone with a similar problem.
      <xsl:template match="/">
        <xsl:variable name="preNodes">
              <xsl:variable name="infoBox" select="$currentPage/chooseInfoBoxes" />
              <xsl:variable name="nodeIds" select="umbraco.library:Split($infoBox, ',')" />
              <xsl:for-each select="$nodeIds/value">
                <xsl:copy-of select="umbraco.library:GetXmlNodeById(.)"/>
              </xsl:for-each>
        </xsl:variable>
        <xsl:variable name="nodes" select="msxml:node-set($preNodes)/*[@isDoc]" />
     <xsl:if test="count($nodes) > 0">
    <div class="related-content">
    <h2>Related Content</h2>
              <xsl:for-each select="$nodes">
              <href="{umbraco.library:NiceUrl(infoBoxLink)}">read more</a>
            </xsl:if>
          </li>
    </xsl:for-each></ul>
      </xsl:if>
      </xsl:template>
