Warren Buckley Ep4, macro not working. Help please
I have followed the 4th Warren Buckley episode in Umbraco TV (Creating a Dynamic Navigation) step by step, twice and the dynamic navigation links are not working. Has anyone else encountered a problem with this tutorial before? Maybe the macro code in the download is wrong or there is a setting I am missing? Any help appreciated
Also I took a quick look at it, it starts at the root and looks for a top-level node with the doctype alias of Home, then lists that and the nodes underneath it. Do you have a level 1 node with a doctype alias of 'Home' in your setup? If not you can change it in this line to whatever the alias of your root doctype is:
Hi Bob,
What exactly isn't working about it?
Hope this helps,
Tom
