solution to those who gets error using umbBlogTagcloud.xslt
For umbraco Version 4.7.1 starter kit blog tag cloud implementation.
If you get "Error parsing XSLT file: \xslt\umbBlogTagcloud.xslt. " while implementing Tag Cloud using BlogTagcloud marco. Please consider the following solution:
Go to developer -> xslt and open umbBlogTagcloud.xslt. Try to save it, if you have this errorSystem.OverflowException: Value was either too large or too small for an Int32.
Change
<a href="{umbraco.library:NiceUrl($currentPage/ancestor-or-self::umbBlog/@id)}?filterby={.}">
To
<a href="{umbraco.library:NiceUrl($currentPage/ancestor-or-self::*[@level=1]/umbBlog/@id)}?filterby={.}">
You should be able to successfully save the xslt this time.
